22re Timing Chain Problem
Old Feb 5, 2011 | 07:19 PM
malcolmr's Avatar
92 TOY! Thanks SO much for your thorough walk through. Absolutely invaluable.
Old Feb 5, 2011 | 08:22 PM
malcolmr's Avatar
Anybody have suggestions for where I should go for a decent cheap radiator for this baby?
Old Feb 5, 2011 | 08:51 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Stealership? Rockauto? One of the many parts places listed in one of the stickies in this subforum?
Old Feb 5, 2011 | 10:12 PM
mightymouse's Avatar
1-800-radiator
Old Feb 5, 2011 | 10:31 PM
  #25
malcolmr's Avatar
Thank you. Sorry if some of my Qs are annoying. Im brand new to this forum and very much appreciate the help you are giving by pointing me in the right direction. I'll check the subforums...
Old Feb 5, 2011 | 10:33 PM
  #26
serioiusly 1-800-radiator it's where i got my last one and they deliver it to your friggin door. https://www.1800radiator.com/
it wasn't a joke and they're prices are were reasonable when i got mine.
Old Feb 6, 2011 | 02:23 AM
  #27
92 TOY's Avatar
got 2 radiators(for the 92 truck and 884runner) from JcWhitney.com....both are Spectra.....both were under $100 delivered. cannot swear to their reliability being that they are aluminum core and plastic housing.
whatever the case, that radiator of your's is done.
do it once, do it right......do a complete job. new belts / hoses / radiator / water pump / oil pump / timing cover / timing set / head gasket / bolts and all the little extras that add up.
you guys have no clue how much it means to me when I come across a thread that has MY thread referenced.
if you were to go to my original thread (THREAD "A" in my sig) and painfully read through it, you would see that not only did it take an extraordinary amount of time to do mine because I was a putz and was VERY low on $$$, but because I had never, ever done any sort of mechanical work before. Now, we have a 2nd project (see my son's 4runner build in my sig) that we are currently working on. Kinda a big jump from then to now.
You can do this.
Old Feb 6, 2011 | 12:24 PM
  #28
91Toyota's Avatar
Btw engn bldr is in Portland too...
http://engnbldr.com/
You don't need to do a "leak down test" on your engine. You just need to get a compression gauge and hook it up the the cylinders one at a time. If you blew a HG one of the cylinders would have less compression than the others.
Good luck!
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
83flatt
Jul 2, 2015 10:30 AM
Badger62811
Jun 26, 2015 09:26 PM
paxanders
Jun 21, 2015 06:29 AM
