22re ticking
Old Nov 14, 2009 | 10:19 PM
turboboost's Avatar
Welcome to owning a Toyota my friend.
Old Nov 16, 2009 | 02:32 PM
Windsor's Avatar
Originally Posted by crawlerjunkie
There is nothing wrong with using water in the carb, I've even used atf. your not dumping it in your just pouring fast enough that it doesn't die. When the water hits the cylinder and the fuel ignites the steam and pressure clean the head and valves. The same way a lightly leaking head gasket will.
ATF is good for un-flooding engines, particularly Mazda rotaries. It's also an easy way to get a well-worn engine to start, as worn rotary engines don't seal for squat at low (starter-spun) RPMs.
When you pour ATF down the intake, warn your neighbors. You'll be fogging up the entire neighborhood when it burns up.
Old Nov 16, 2009 | 02:55 PM
INFINITY's Avatar
Originally Posted by Teuf
Adjust valves anyway, its fun.
x2
doing hot valve lash adjustments suck i wish they were more like hondas and meant to be done cold.
if you EVER hear a "quiet" 22re i would be very weary of the person selling it. reason is that i have heard a quiet one that on inspection there was no valve lash (spacing) in there at all. they were claiming that it was recently rebuilt. ha, no joke.
Sidherish
Aug 2, 2015 01:42 PM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
Gamble_STi
Jul 7, 2015 07:54 PM
