22RE stumbling worst now...
Old Mar 23, 2015 | 02:41 PM
  #41
Tommy T.'s Avatar
Originally Posted by bswarm
No, that's the wrong way and only screws up the entire A/F ratio. It's under an aluminum plug on the top. Drill a small hole in the plug being careful not to drill too deep or you'll bury the adjust screw under it. Put a screw in the hole, wiggle out with pliers. Adjust a little at a time, more than 1 turn you have other problems. After adjustment, Put old plug or other cap in to prevent water or dirt getting in. Here's a photo showing plug removed on my truck...
Glad I found this thread. Engine in my 88 is tripping up at low RPMs. When standing in front of the truck, which way should I turn the screw to aid low RPM mess?
Old Mar 23, 2015 | 05:25 PM
  #42
bswarm's Avatar
Clockwise is richer, other way is leaner.
Old Mar 24, 2015 | 03:13 PM
  #43
Odin's Avatar
Make sure you don't have any vacuum leaks before you do this or you'll never get a good setting!
Mark the screws slot position on the aluminum casting with a permanent marker so you have a starting reference point. You could always scratch it into the casting with a sharpened nail if you're worried about it.
Now turn the screw maybe 1/4 to 1/2 a turn and see what it wants. If the idle gets smoother you went the correct direction. If not go back to your reference point and turn it the other direction.
Old Mar 24, 2015 | 03:23 PM
  #44
bswarm's Avatar
I can turn mine full rich and still pass Ca smog check. I'm pretty sure Toyota restricted how much it can be adjusted, as earlier years had much more adjustment capability. The next time I have the AFM out I'll see if I can find what they did.
Old Mar 24, 2015 | 03:53 PM
  #45
Odin's Avatar
If clockwise makes it richer perhaps the older years were equipped with a longer screw and or the casting has deeper threading?
Old Mar 24, 2015 | 04:00 PM
  #46
bswarm's Avatar
I've got a hunch they put a small air bleed bypass in it, it could be as simple as a hole to plug.
Old Mar 24, 2015 | 05:31 PM
  #47
Odin's Avatar
I wonder if it's a threaded in jet or a simple hole they drilled from the factory?
Might be different sizes depending on the application from the factory.
Old Mar 25, 2015 | 01:37 AM
  #48
lonfu's Avatar
did you use propane to check for a vaccum leak?
crammit442
7
Nov 29, 2017 12:30 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Wooddmiester
Aug 11, 2015 07:42 PM
jjrbus
Aug 10, 2015 01:09 PM
Dakotaneu
Jul 27, 2015 12:03 AM
