22re problem
Old Sep 8, 2009 | 08:08 AM
874runnersr5's Avatar
22re problem
hey everyone, alright so heres the run down ive got a 87 4runner 5spd 22re
On my way to go wheeling yesterday, on the highway my truck seemed really gutless. Not much power at all, when i took the off ramp the it seemed like it was missing/ on/off type power deal. Anywho, i kept driving, went away then it would come back at certain times. I could still do the speed limit 90km/h. Sometimes it would run like normal, no problems at all. So i get to the staging area and get out and my exhaust sounds different. So some of the yota tech took at look and figure #2 wasnt firing They swapped the plugs from #3 over to #2 then 3 had the problem. So we tried to fix the wire and it somewhat worked for the entire day. On the way home she ran flawless. No problems at all, i get home swap over my old set of spark plug wires, no luck exhaust still sounds funny. I checked the cap for carbon tracing and now im stumped..
what could it be? it feels like sometimes that cylinder is cutting out..
Old Sep 8, 2009 | 08:23 AM
crafthorse's Avatar
Could the coil be bad? Is the distributer loose? Those are the only thing that come to mind, but I am sure someone with more experiance will come along soon.
Old Sep 8, 2009 | 08:28 AM
hmm, if the coil was bad wouldnt that effect all the cylinders..
i hate this, i wanna get it fixed!
Old Sep 8, 2009 | 08:50 AM
olharleyman's Avatar
Rotor/Cap?
Old Sep 8, 2009 | 09:01 AM
rdrttoy's Avatar
were the plugs ok?
Old Sep 8, 2009 | 09:07 AM
plugs look bit hagg'd but nothing new
Old Sep 8, 2009 | 09:18 AM
mightymouse's Avatar
I would go to the parts store and get a rotor, cap, and new ngk plugs. if that doesn't work check your valves. then timing then compression test. this stuff is cheap and is easy to do. Also check for any vaccumm leaks.
Old Sep 8, 2009 | 09:56 AM
crafthorse's Avatar
Yeah it probably would, but I threw it out there because you said you checked the cap rotor etc...Like I said someone with more exp will come along.
Old Sep 8, 2009 | 10:25 AM
Yea, im waiting for abe or dc to chime in
im thinking compression test to, but if it were say a stuck valve, or something else wouldnt it be a constant loss of power thru the cylinder
Old Sep 8, 2009 | 10:40 AM
toyota4x4907's Avatar
They swapped the spark plugs over from 2 to 3 or the wires? because in there you say the plugs, but then say the wires......
Old Sep 8, 2009 | 11:24 AM
g_cali's Avatar
Start with the cheap stuff. Cap, rotor, plugs, plug wires...
Old Sep 8, 2009 | 11:55 AM
metal09's Avatar
i have a 1989 toy same prob then i changed out the plugs and rotor and wires and it seemed to fixed the prob.
Old Sep 8, 2009 | 01:24 PM
hmm, im gonna ask my friends that work at toyota to get me oem rotor/cap and wires
Old Sep 8, 2009 | 01:31 PM
iamsuperbleeder's Avatar
yeah, I'll 3rd (or is it 4th ) the cap, rotor, and plugs, and MAYBE the wires
when silly little stuff like that happens, it's often the simplest thing, lol
best of luck, and keep us posted!
Old Sep 8, 2009 | 03:26 PM
Yeah, not sure if i should go oem and or aftermarket for wires/cap/rotor.
i just was tinkering around with it, the exhaust sounds funny, then sometimes itll sound normal again..
hmmm interesting interesting.
Old Sep 8, 2009 | 04:28 PM
dude a new $10 basic brand cap from the parts house is going to work better than a $20 OEM cap that's BAD lol, catch my drift?
I've never had any issues with the brand BWD from Advance Auto Parts, either the cap or rotor, but I do use NGK wires, and E3 plugs, but NGK plugs would be my second choice
Old Sep 8, 2009 | 04:40 PM
yeah, i got bosch wires on now
Old Sep 9, 2009 | 03:53 PM
Replaced plugs, power wise its back to normal, sound wise. the exhaust still sounds a bit funny
Old Sep 9, 2009 | 03:59 PM
abecedarian's Avatar
oops. guess I'm too late.
Anyhows....
If you moved the spark plug from #2 to #3 cylinder and the problem followed the spark plug from #2 to #3, the spark plug was 'most likely' the problem.... but could be that the wire wasn't seated correctly to begin with.
Actually a good trouble shooting test- if you have a misfire in one cylinder, swap the sparkplug from that cylinder with another sparkplug. If the misfire moves to the new cylinder, the problem is likely with the sparkplug you moved. If the misfire remains in the same cylinder as it was initially, then you're stuck troubleshooting an issue with that cylinder.
Old Sep 9, 2009 | 04:00 PM
Yeah, i have no idea why my exhaust sounds different tho.
I know my muffler is dying, but ive never herd my truck make this kinda sound. It sounds like totally fine while revving/driving. Im thinking i need a good tuneup.. but i have no idea where to start.
