22re new head, cam, timing kit
Old Dec 23, 2009 | 05:17 PM
  #61
lyncoo's Avatar
congrats looks like you did a good job
Old Dec 23, 2009 | 05:20 PM
  #62
1990yota-pickup's Avatar
do did u call around town and figure out how much you saved..
by the way did you use a torque wrench when you tighten up those head bolts
Old Dec 23, 2009 | 06:01 PM
  #63
75k5toy's Avatar
I'll For a job well done. salud. merry Xmas.
Old Dec 23, 2009 | 06:58 PM
  #64
toyomoto's Avatar
hey does it lope pretty good when your at idle? also when putting a new cam in its a good idea to run the motor at about 2k for about 15-20 min so the cam seats correctly. just FYI for the next one
  #65
toyomoto's Avatar
HAHA!!!! you got 2 door handles! HOW!?!?!
Old Dec 23, 2009 | 07:02 PM
  #66
Teuf's Avatar
It is such a great feeling when that happens, the after put back together start up.
Old Jan 3, 2010 | 01:14 PM
  #67
txclimber's Avatar
I did call around and it looks like I earned around $2000. That's the estimates for the labor alone.
It seems to be idling fine, no loping. It does idle higher than it used to though. I may recheck the timing. I've been out of town and haven't done anything since I put it back together.
Old Jan 3, 2010 | 01:37 PM
  #68
u need to talk 2 grand out the old lady.. sense you saved that much
Old Jan 3, 2010 | 06:21 PM
  #69
TheJollyGreenGiant's Avatar
Yea whats the deal with the two inside door handles??? Good Job by the way.
Old Jan 3, 2010 | 08:50 PM
  #70
Teuf's Avatar
MM i just noticed that too, 2 door handles. I said many times, Ah Dear do you know how much i saved us on labor doing my cyl head, please give that saved money for n SAS... Soon Sooooooon......
Old Jan 4, 2010 | 12:14 AM
  #71
86 TOY's Avatar
Good stuff! Congrats on the great work and saving $2000!!! I bet she runs like a dream. Most insipiring part is new head, cam and timing kit in 1 WEEK and not a mechanic! Man I need to jump in on mine...
Old Jan 4, 2010 | 04:23 AM
  #72
what are u waiting for???
Old Jan 4, 2010 | 06:30 AM
  #73
txclimber's Avatar
86toy-You've got it. Go for it. My only tidbit of advice would be to gather all the parts and tools you think you'll need before you start. Inevitably, you'll have to go get something else that breaks along the way. The quicker you can get it all put back together the less you forget. Start a thread, lots of good help on this site.
2 door handles? These old 4runners don't have back doors. Rear most door handle is for the person in the back seat to use to get out. At least that's what I've convinced myself. Pretty silly actually.
Old Jan 4, 2010 | 06:53 AM
  #74
do you have a garage to work in? makes a big difference.. then out playing outside in the cold (no fun)
get all your parts all at once.. and think everything out it will be alot easier. read over your hyanes manual a few times.
if you dont have a garage.. you can alwaya pic up a tarp and clothesline, kersones heater.. not the prefered method but it can work..
Old Jan 6, 2010 | 05:11 PM
  #75
jmacd's Avatar
How is the ENGNBLDR head and cam going for you? I am preparing myself to do the top and front end on my engine and thinking of going with that same setup you did and just wondering how it worked out.
And my 87 4runner has the 2 door handles and my old 88 did too. Weird stuff.
Old Jan 6, 2010 | 07:35 PM
  #76
86 TOY's Avatar
Thanks, working on acquiring some tools first. I agree on the quicker you put it back together the less time you'll have to forget. Another reason why I'm putting this project on hold for now.
Thanks. Yes, I have a garage but its only supposed to get up to 15 this weekend with a low around 1, snow also on the way!!! Man that tarp and kerosene heater would suck in this weather!
Old Jan 6, 2010 | 07:44 PM
  #77
lyncoo's Avatar
x2 i want to know about this head and cam combo
Old Jan 8, 2010 | 03:20 PM
  #78
there is a guy in Atlanta doing the tarp clothes line method to replace the head gasket on his 3.0 v6
it just dumped alot of snow in atlanta last night..
Old Jan 8, 2010 | 07:05 PM
  #79
lyncoo's Avatar
i guess you lose 90hp
Old Jan 9, 2010 | 08:24 AM
  #80
txclimber's Avatar
The new head and such seem to be working just fine. I've had to deal with a little overheating problem. Seems everyone is right about that dang 2 stage thermostat. I had one in my truck before the rebuild which unexplainably went bad after I put the new head in. I tried the cheap Auto Zone thermostat. Bad temperature overshoot problem. Did the old drill a hole trick. Works great. Too great. Now it runs a little cooler than it should. Called Toyota to pick up the real deal. $45. Yep, for a thermostat. Damn.
As far as the question as to improved hp or performance. Not much over stock. It is way better than it was before though, because it was running so poorly. I assume if I put a header on it I could get lots more hp, but I'm happy with it for now.
I like the setup with the street rv and 268 and would recommend it to anyone using their truck as a daily commuter. Engbldr says it adds around 5% increase overall. Sounds good to me.
