22re idle problem
22re idle problem
I have an 89 4runner 22re, it recently started idleing rough. Fuel pump is new. When cold it idles perfectly. after about 2 minutes it acts like it "loading up" on fuel,getting too much fuel. If I rev it and hold rpm at about 2k it runs great, but wont idle. I checked the cold idle injector to make sure its not leaking, its good. I ran the codes although cel was not on, it gave me a 41 , so I changed the TPS. Not sure if I have it adjusted right, but it still idles smooth when cold then gets rough and dies. It will still run good at higher rpm. Have checked plugs and wires, all are ok. cleaned throttle body. and all injectors are firing. I'm baffled, any advice would be appreciated, thanks
steve miller
Oct 10, 2015 01:40 AM
Jnkml
Jul 6, 2015 01:20 PM
