22re head is too tall????!!!!
Old Mar 14, 2009 | 09:30 PM
Philosopher's Avatar
I am looking at a 87 4Runner I want to buy cheap. The owner had the motor rebuild and got a ported,rebuilt head for his machinist while at it. He traded in his old head as a core for the new one.
The new head is taller than the old one -- the timing chain is now too short. He said that the combustion chambers are larger, and the head is simply taller. I am trying to sort this out. He thought he might have a Supera/Corolla head?
Can anyone help with this?
Thanks!
Old Mar 14, 2009 | 09:58 PM
toyota4x4907's Avatar
'84 and older 22rs had "taller" heads and block height.
Old Mar 14, 2009 | 10:12 PM
Plumbrbob's Avatar
This is a qoute from a 22r guru
Originally Posted by engnbldr
*Morning!
Wow, I actually got this site open on my dialup system! Of course it took three cups of coffee but that's ok.
There sure is a lot of confusion on the year changes but I see lots of you have it right.
I gave up on the serial numbers, now I just use my tape measure, or look closely at the side of the block for that bow tie shaped pad on the 1985 and later.
The early block is 11.280" tall, the late one is 11.090" tall. 1981 to 1984 is early, 1985 and up is late but watch out for the 20R, those pop up regularly.
It seems that these engines have been swapped around, changed over, had things bolted on that don't belong, on and on and on. But the tape measure doesn't lie.
Between the early and late the only things that interchange for sure are the rod bearing inserts, the head gasket, and the freeze plugs.
Yes, early is 98 link, put one of those chains on a late engine and start it and she will let you know...Late is 96 link. Even more fun is the 1981 to 1982 is a dual full roller, all the rest are single. But don't count on that, hundreds of the very early engines have been converted to the dual roller, and lots of late engines have been converted to the aftermarket dual $$etup...
Yep. Tape measure, works every time....*EB
Good luck man
Old Mar 14, 2009 | 10:38 PM
abecedarian's Avatar
The deck height (crank centerline to head surface) was reduced in 85 with a corresponding increase in head size (cam centerline to head surface):
•Early 20R Blocks 75-80 9.120"
•Early 22R Blocks 81-84 9.120"
•Late 22R/RE Blocks 85-95 8.930"
(measurements courtesy of LC Engineering)
If the head is too tall, that would imply the block is an early block.
Old Mar 14, 2009 | 10:41 PM
Originally Posted by toyota4x4907
'84 and older 22rs had shorter heads and taller block height.
There, fixed it for you.
Old Mar 14, 2009 | 10:57 PM
Oh. I guess I shouldn't comment about stuff I'm not 99% sure about
Thanks, Abe.
Old Mar 14, 2009 | 11:05 PM
Thanks, Abe.
Don't let 99% be your limit.
50% is good enough. That means you have just as much chance being right as being wrong.
I'd give you a kiss, but you're built funny.
Old Mar 15, 2009 | 12:08 AM
It's not nice to make fun of people's imperfections
Old Mar 15, 2009 | 12:17 AM
So you're saying being 'male' is an imperfection?
That may explain your confusion with head size....
Old Mar 15, 2009 | 12:28 AM
space-junk's Avatar
abe, why did you have to bring the thread down to this level??? lol...
Old Mar 15, 2009 | 12:33 AM
I haven't been around as many heads as you have, so I speak from inexperience.
Old Mar 15, 2009 | 04:02 AM
mistreatedtoys's Avatar
The early block and the new block are hard to tell apart except for one thing. If I am correct the later model block is called a lazer block. On the exhaust side of the engine there is a big casting mark, it is round with 2 ears on it. This is where an area is machined for the turbo oil supply. It is pretty large and easy to spot.
Old Mar 15, 2009 | 08:49 PM
So, do you think that if the head is too tall, then the motor probably is out of a 84-84 truck?
Old Mar 15, 2009 | 08:54 PM
here's a pic of the late block:
if yours does not have the casting like what's in the pic, it is an early block
Old Mar 15, 2009 | 08:59 PM
That is exactly what I needed! I emailed the seller the pic. Thank you! Thank you! Thank you!
peace and grease,
-steve
Sep 4, 2015 09:27 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
DrZero
18
Jul 24, 2015 11:31 PM
jake_v
Jul 22, 2015 03:17 PM
ryerye13
Jul 14, 2015 08:27 AM
