22re has gas and spark but won't fire
Old Mar 6, 2013 | 10:51 PM
91_Hilux's Avatar
Driving home the other day and the truck overheated so I called a ride and while waiting started the truck and drove about a mile til she got warm again, then towed it most of the way home about a mile from my house we stopped and I was going to start it and drive it in the drive way but it wouldn't start... so we pop started it and I drove it up to my house now a week later it won't fire, it turns over and will start to stumble after a couple seconds but never actually fires up, I'm sure my radiator is junk and I think I need a tps but it should at least fire without them right? Idk it's kicking my ass so any help is appreciated.
Thanks
Old Mar 6, 2013 | 11:12 PM
Co_94_PU's Avatar
Since it overheated my first suggestion would be to make sure it didn't damage the head gasket. Go to the local autoparts store and use thier loan a tool program and get a compression test kit.
You can pick up a multimeter from harborfreight.com (or thier local store) if you don't have one for really cheap.
With a test meter in hand inspect the TPS, don't guess diagnose
FSM Link, throttle position sensor is under engine and then MFI.
The thermostat test is a pretty simple and free test also, it's covered in the FSM, basicly put it in hot water w/ a thermometer and make sure it's opening.
There is also a trouble shooting chart in the FSM engine section, locate your issues "Does not start" "Difficult to start" "Engine overheats", and work thru the inspections. They are listed with a number that indicates which order to check.
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Doug4320
Mar 24, 2018 10:11 PM
Sandman
Jul 14, 2015 12:36 PM
ryerye13
Jul 14, 2015 08:27 AM
