22re Fuel Efficiency + Cat Conv.
Old Jul 30, 2013 | 09:00 AM
  #41
AdmiralYoda's Avatar
Originally Posted by highonpottery
Sounds like you found your problem. Look up Bosch o2 sensors here on YT and you'll see several complaints and problems with them. Denso is what you want - just bought some on amazon for less than $60/ea.
wiring install should only be a plastic clip connection, no splicing involved unless someone clipped the pigtail from your wiring harness.
Is it the Denso 2341056? Rock Auto has them for $19.94 after a 5% discount code.
I'm about to buy one for myself. When you say $60/ea I'm wondering if I'm looking at the wrong one?
Old Jul 30, 2013 | 01:54 PM
  #42
dawa88's Avatar
hmm Im pretty sure mine is a 4 wire o2 sesnsor, so itll either be DENSO 2344050 or DENSO 2344056, but thanks for the suggestion, thats definitely the best deal Ive seen so far.
Old Jul 31, 2013 | 01:44 PM
  #43
dawa88's Avatar
So on my drive to work today, the check engine light came on for the first time. It may be possible that on monday I jarred the o2 sensor loose during my ebrake install. Any ideas why it wouldnt have been on prior to that?
Previously all signs pointed to o2 sensor except the check engine light... Is it possible to clear an error? I wouldnt put that past the previous owner if it was.
Old Jul 31, 2013 | 04:28 PM
  #44
thefishguy77's Avatar
Probably O2 if that's what your gut says then crawl under and make sure you didn't somehow work the plug loose or bare a wire. Easy stuff to check as soon as I put my O2 back in after header install my cel shut off after ideling for about a minute
If you just want to reset any codes you should just be able to unhook the positive battery cable and go inside a watch tv for an hour or two. Then hook it back up and you should be good to go. At least that's how it works on my 99 Chevy with a 5.3 motor
Old Aug 21, 2013 | 05:40 AM
  #45
dawa88's Avatar
Alright, o2 sensor was definitely the porblem. Went from getting 400km/tank to getting 600km/tank (70L tank). Thanks for all the help!
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
montanatruck
Feb 26, 2017 07:07 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Fundy Rider
Jul 16, 2015 01:35 AM
