22RE Flamethrower injector review
Old Mar 20, 2015 | 01:46 PM
87hoerunner's Avatar
Hey all,
I was lucky enough to be one of the fortunate ones to test out flamethrowers new injector last year in test phase. And here is my review.
Injectors housing quality is excellent. No weak looking points or cheap plastic on connectors. Injectors included adapter harnesses that i wasn't to enthusiastic about until I took a closer look at them. Plus side to the adapters harnesses is that if your clips are broke on your factory injectors this makes for a good chance to make em right by just using zipties. Will post pics later, but by wrapping zip tie around factory broken plugs and around adapter you can lock them together and not have to worry about plug coming undone.
First thing i noticed when running the vehicle was the smooth idle. Idled better than ever before. Truck could pull hills without having to gear down as much. Fuel mileage increase of .80 mpg. Will update more of review as i have time.
Vehicle: 1989 4Runner 22RE 5 Speed Swap 4.30 Gears 33x12.50 15 MTZ 4"Trailmaster
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
steve miller
Oct 10, 2015 01:40 AM
Tacoma1313
Aug 17, 2015 05:44 PM
