22re engine hunts
Old Apr 15, 2009 | 03:36 PM
Ride On's Avatar
Question 22re engine hunts
I have a 94 Toyota truck with a 22re engine and the idle hunts anybody know what causes this? it's not the tps
Old Apr 15, 2009 | 04:22 PM
Flash319's Avatar
Idle is to high. Once your idle-E2 contact is closed on the TPS and the engine is up to temp your idle can not go above about 1100 or it will start doing that. This can be caused by a vacuum leak or improper idle screw setting.
Old Apr 15, 2009 | 07:30 PM
Ride On's Avatar
thanks man
Old Dec 15, 2017 | 03:16 PM
Kent2's Avatar
Engine runs great until I turn on heater blower to HIGH. Then the engine "hunts". It acts like the tranny is shifting in and out of OD.
Old Dec 15, 2017 | 03:54 PM
RAD4Runner's Avatar
Kent2,
As mentioned about idle above.
I had similar problem when AC is on and I stop at ramp from freeway speed. Got fixed when I adjusted idle to spec.
Old Dec 15, 2017 | 04:43 PM
Thommo Thompson's Avatar
yes its usually related to a vacuum leak or fuel pressure regulator, and coincidently, its often a vacuum leak at the pressure regulator vacuum hose!
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
bryan34w
Jul 6, 2015 05:53 PM
