22re cylinder head replacement/timing chain adjuster help
Old Mar 31, 2016 | 04:48 PM
gixxer's Avatar
I replaced my cylinder head on my 22re...I forgot to put a wedge down into the timing chain tensioner to keep it from coming out...well now I can not put the cam gear back on. Is there any way to release chain tension without removing the timing chain cover so I could put the cam back on ?
Old Mar 31, 2016 | 11:42 PM
wyoming9's Avatar
Red face
It has been a few years
So the old tired brain might not recall correct
I never used anything to hold the chain tensionor
Put the bottom all together set the head on then put the cam gear on
Someone with fresh memories might have a better idea.
First I heard about this wedge idea
Old Apr 1, 2016 | 11:57 AM
gixxer's Avatar
I was able to stick a long rod down in there and push the adjuster in, then the cam went on without any problems.
https://www.yotatech.com/forums/f116...t-22re-159401/
Old Apr 1, 2016 | 08:24 PM
85TurboRunner's Avatar
Old Apr 4, 2016 | 06:36 PM
an1176's Avatar
Put part of the chain on the cam sprocket the put sprocket on cam then turn the cam until the chain goes back on. Like you would with an old bicycle chain and sprocket.
millennium falcon
Mar 19, 2017 05:42 AM
bluAM2
Sep 15, 2016 09:35 PM
d-wood
Mar 8, 2016 07:40 PM
an1176
Mar 3, 2016 03:26 PM
Naked Runner
Feb 16, 2016 05:36 PM
