22RE compression ?
Old Oct 30, 2006 | 07:32 PM
4RunnerLVR86's Avatar
Question 22RE compression ?
When I rotate the motor with the oil pan off air comes out of #3 cylinder from the bottom. The spark plugs are all in. What could it be?
Old Oct 30, 2006 | 07:39 PM
dcg9381's Avatar
Some air leaking down is normal.. But it shouldn't be a lot.
There's a test for this sort of thing, it's called a leak down test.
It's most likely rings.
Old Oct 31, 2006 | 04:37 PM
Flash319's Avatar
Broken rings. A little is okay but not to much. I pulled apart my 88 22re with 300k mi on it as it was leaking by really bad. Every ring on every piston was broken. #4 rings were in little pieces but still in place. Was running good to. I would just drive it till it craps out. You will have to rebuild it all anyway.
JNapolitano
Nov 14, 2019 07:46 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
RatOmeter
Oct 22, 2015 03:17 PM
thefishguy77
Jul 30, 2015 10:59 AM
