22re code 22
22re code 22
I have a '89 4runner with the 22re and been having a check engine come in and go away every time I drive it. It also makes the engine stumble while the light is in, usually 5 seconds or so, and then go back to running great.
I pulled code 22 off it which is the water temperature sensor alarm. Any ideas of where I should start? I also don't understand how that code would make it run so rough.
Thanks for your help,
Jesse
Jesse
I don't know where you're getting the idea your code refers to an "alarm," so here's the page of the Service Manual.
http://web.archive.org/web/201410310...26diagnosi.pdf
The ECU needs information on the engine temperature for, well, everything it does. So a "stumble" while it can't determine temperature sounds pretty benign.
Since yours comes and goes, you might have a bad wire. You can look for that simply by wiggling the harness while someone watches for the code. You COULD have a bad sensor, which you could check before you spend money on a new one, but I like to start with the easiest/most likely items first.
