22RE blown head gasket cure?
Old Apr 6, 2009 | 10:44 AM
  #61
Dirt Driver's Avatar
Originally Posted by Lumpy
Watch running without a stat, engines tend to overheat without one. I think what it is that the water does not stay in the rad long enough to cool and then you have problems. Really keep an eye on your temp. If you do run without one for a while you can make a small restrictor plate. You may need to experiment with different size holes, if you have an issue with over heating. Just a thought...
If anything, removing the thermostat will make the engine run colder and very slow to warm up. The cooling system is not largely dependent on the speed of coolant running through it nor the time it has to transfer heat to the radiator. I think that misconception comes from the fact that most people remove the t-stat because they have cooling system problems to begin with.
It will also cause the ECU to stay in open loop longer(or permanently) and it will reduce fuel economy, increase wear, oil contamination, and possibly sludge formation.
Old Apr 6, 2009 | 05:31 PM
  #62
Lumpy's Avatar
A while back I was talking to a guy I worked with...his father-in-law used to race stock and modified at the local track. They had to run restrictor plates to keep them from over heating...I figured the same held true here as well. I could be mistaken, I my self have not run without one.
Old Apr 6, 2009 | 09:52 PM
  #63
I found a forum entry on another site a while back that thoroughly explained why the coolant can't really "move too fast" through the radiator, but I'm having a heck of time finding it again. I thought I saved it, copied it, bookmarked it, etc.
Old Apr 26, 2010 | 12:36 PM
  #64
Montana_Jon's Avatar
how's it doing a year later?
Old May 10, 2010 | 07:02 AM
  #65
Buster Bloodclot's Avatar
I used one of the can repairs last year in my '92 22RE. It worked-for awhile. My HG leak is external so I just lose coolant slowly. Anyway, the leak is back now.
Old May 10, 2010 | 03:25 PM
  #66
tnx, I'm gonna give it a try, I've got a new engine, so with 180k on a 22re with a blown head gasket with white smoke and antifreeze in with the oil, Nothing I can really ruin that a new engine won't fix or that a rebuild (which I plan to do slowly on the replaced engine) won't fix. sorry to specify so much but I want ppl to be able to find this in the threads easily. Tomorrow will start the test and I'll report back tomorrow afternoon.
Old Jun 5, 2010 | 05:44 AM
  #67
myyota85's Avatar
well did it work?
Old Jun 5, 2010 | 08:50 AM
  #68
well for the cost I decided to just rebuild the head, like $150 worth of material. I sold the 4runner though so someone else is rebuilding the head, so sorry but IDK.
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
