22re+5speed+4.10gears+tire size?
Old Jun 10, 2009 | 04:10 PM
greatskiiiier's Avatar
ok, so i have a stock height pickup with a recently rebuilt 22re with a 5 speed and i make it out (from the code) to have 4.10 gears front and rear
right now it has 31" tires with 4.10s, it drives good exp going up hill in 5th- which i have to downshift
so how would my truck do still at stock height with some 33x10.5s?
how will this effect my power when i have some weight in the bed/ hitch as well
EDIT: ok im reopening this- i did some research and i found out that when the guy put the 31s on my truck. he never adj the speedo, so i made a little chart of my speeds based on what my speedo says, what im actually going at with the 31s, and what i would be going with 33s..... also- i just measured my tire-fender clearance, and my rear is a god 1.5 inches higher (obv due to pickup) but do they sell leveling kits for that?
this is all @ 3000rpm (where i usually shift)
........speedo
gear...says......31".......33"
1........15........17........18
2........28........31........33
3........44........48........52
4........61........67........71
5........72........79........84
based on that info- i dont think that 33s will show that much of a difference when driving- yes it will be slower, but i dont think it will be that noticable
Old Jun 10, 2009 | 04:33 PM
KVRunner's Avatar
With 4.10 gears you will probably feel a major loss in power and with a trailer on it, it will be 10x worse.
Old Jun 10, 2009 | 04:35 PM
waskillywabbit's Avatar
It will go from a turtle to a slug.
Old Jun 10, 2009 | 05:15 PM
SpecialScottie's Avatar
Get some factory 4.88s and youll be golden
Old Jun 10, 2009 | 06:45 PM
Stuwy123's Avatar
Factory 4.88's are hard to come by. 4.56's are readily available. They are part 31" tire and tow package.
Old Jun 10, 2009 | 09:55 PM
whokrz's Avatar
At stock height and 33's you will need to trim the body.
I like 5.29 gears and 33's you can pull hills in 5th
Old Jun 17, 2009 | 03:35 PM
bump- read edit
Old Jun 17, 2009 | 05:02 PM
whokrz's Avatar
When I ran 33s with 4.10 gears it was pretty close power wise to 31s on flat ground. When I was on hills I could feel the loss of power. With 31s I would climb a hill in 4th gear and with 33s I would be in 3rd.
If you are getting 33s for offroad use you can always run cheap 31s off of craigslist and put on the 33s when you go offroad.
I have 5.29 gears and run 32s on the street and 37s offroad.
Old Jun 17, 2009 | 09:33 PM
Keith B.'s Avatar
22RE + 4.10 = 29" tires. I changed mine to 4.56 + 31" tires, feels correct.
Old Jun 18, 2009 | 07:20 AM
Lumpy's Avatar
31's do alright on stock gears...I would not go to 33's and expect to keep pace with traffic on the hills.
Old Jun 18, 2009 | 12:37 PM
i dont keep pace with traffic on hills with the 31s... heck even in my brothers cherokee i wouldnt keep pace with traffic (although i did fall farther behind in the toyo)
i dont mind not keeping pace, but i dont want the truck to be unsafely slow- or make it impossible to tow anything if i ever needed to
Old Jun 18, 2009 | 10:13 PM
dan8906's Avatar
i have 32's and 4;10 and i feel the loss going up hills pretty bad, if i had the money i would instantly get 4:88 gears
smilen724
13
Nov 8, 2015 04:11 PM
Gravel Maker
RuffStuff
Oct 4, 2015 10:26 AM
oldblue
Sep 28, 2015 04:07 PM
gp66
Sep 14, 2015 12:10 AM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
