22RE OR 4.3 GM Motor
Old Jun 26, 2012 | 12:55 PM
EFI85's Avatar
Originally Posted by Numbchux
You guys have different definitions of pulling a boat. I'm talking about 3k lbs at freeway speeds, with enough gear in the rig for a weekend away. .
It was a pretty straightforward swap, one of the easiest I've ever done (I've been involved in dozens of subaru swaps, including into multiple VWs, dune buggies, and even an RX7), certainly the best-documented. Would have been even easier if I had done the 4" bracket lift instead of a 2" body/drivetrain lift.
More power than the 5VZFE, cheaper to buy, cheaper to maintain, fits like a glove. Of course, the 5VZFE swap was not nearly as well-documented when I bought this truck as it is now, so it's a much more viable option, but I still don't think it holds a candle to the 4.3.
MY boat and trailer is about 3k id assume and i got enough room between the room in the boat and in the bed for plenty of gear ..just saying bro lol
check out my photo album.
Old Jun 26, 2012 | 03:36 PM
islanderoffroad's Avatar
Can you SC a 4.3?
GM did turbo them from the factory for a few years.
Old Jun 26, 2012 | 03:37 PM
Originally Posted by 89yota22repower
i have a buddy that has a 86 4 runner with the 22re.. he wanted to do the 4.3 and he got it in and couldnt figure it out nor come up with the rest of the funds to finish it.. he stopped junked the 4.3 motor got another 22re. and is now doing the 3.4 coversion.. the 4.3 is bad news. keep it toyota with the 3.0 or 3.4
I wouldn't say its bad news, its a great motor. Swapping anything in where it didn't come from the factory is going to take work. Some more than others.
Old Jun 26, 2012 | 03:54 PM
BigBluePile's Avatar
Turbo......meh......
Old Jun 26, 2012 | 05:40 PM
  #25
91_TOYOTA_4x4's Avatar
Turbo..... Heck yeah!!!!!
Imagine a 2.7 with low comp pistons, CT20B at about 10-15 psi. I see an easy 250hp and torque to back it up. Plus you still retain the mpg when you crusing out off boost and when that 3k trailer or hill comes just spool her up and pretend you have a 350 in there
Me- well i feel a aristo 2JZ on stock JDM ceramic turbos, 3.5" exhaust, nice hefty fmic, and a bit of boost in my 4runner in a year he he and hey its still a 3.0L lmao
Old Jun 26, 2012 | 06:21 PM
  #26
fork's Avatar
since this thread is limited to a 22re or a 4.3, I would keep the 22re. but in my opinion modifying a 22re for power is more of a headache than it's worth... skip a 4.3 and locate a 3rz vehicle and swap that instead
Old Jun 26, 2012 | 06:30 PM
  #27
Agreed^^^ sorry just giving ideas beyond a 4.3.
Your right though. A 22re can only go sofar and honestly turbos dont enjoy them so you can only do a cam and exhaust which to me makes a 22re perfect. And yeah if you really need to do a swap just do a 3rz
Old Jun 26, 2012 | 07:11 PM
  #28
TrikeKid's Avatar
If you've got a good 22RE now, toss a cam and header on and call it a day. If that's not enough, the 4.3 is a kick ass little engine, and what will end up under the hood of my truck if my 22R ever goes tits up. The 3rz is another good option if you can find a cheap donor, but a cheap donor for the 4.3 isn't an if, it's a matter of hitting CL and finding one.
Old Jun 26, 2012 | 07:38 PM
  #29
BUST'EM504's Avatar
I am in the same my 22r and my trans just crapped out
Old Jun 26, 2012 | 07:58 PM
  #30
Here ya go: http://skagit.craigslist.org/pts/3077884638.html
Old Jun 26, 2012 | 08:08 PM
  #31
travis_h's Avatar
I would go with the 4.3 imo, but I like to have the extra power and build all my own stuff. I had a 22r did a rebuild cam header intake and 5.29's and it did ok for power and good on fuel the 4.3 probably won't get as good on mpg. The 22re will be easier though. If you want lots of power and don't care about your fuel bill each month go 4.3 or 22re for a little less power but more fuel friendly. Or like me and build a 350 with way to much power and 7-9 mpg and break stuff.
Old Jun 27, 2012 | 11:55 AM
  #32
Numbchux's Avatar
But not 9-10?
Maybe. Typically 8ish is about the limit for a streetable setup on N/A compression. The engine I'm using has a 9.1:1 compression ratio, whereas the Typhoon/Syclone engine had an 8.35:1 (according to wikipedia...). You can run high boost and high compression, but it requires reliable high octane fuel, and a VERY good tune to manage it.
Our #171 Rally car is running about 20psi of boost on about 11:1 compression, but that's on 105 octane race gas, and we flew a former Prodrive engineer over from England to tune the car....
How does that setup do on the freeway? My parents have a MasterCraft ski boat, we always have my uncle tow it with his half ton (of course, my parents both drive Subarus....so that's not happening). Pretty sure a couple hundred freeway miles with that behind a 22RE 4Runner + 1k lbs of gear would make for a very miserable trip.
And yea, the OP is asking about keeping the 22RE, or swapping for a 4.3. If he has an opportunity to buy a running 4.3 donor vehicle for next to nothing, than any other engine swap is going to cost at least double, probably more.
cars-guy
Aug 16, 2020 06:59 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
keithporter83
Jul 24, 2015 07:37 AM
msane99
Jul 17, 2015 10:13 AM
