22re to a 2.7
Old Apr 20, 2007 | 04:25 PM
90_yota's Avatar
22re to a 2.7
how much difficulty is it to swap out the 22re in a 90 toyota pickup for a 2.7 from a 1998 toyota pickup? i can get a real good deal on the 98 that was rolled so i would have the donor truck.
Old Apr 20, 2007 | 04:26 PM
Brendan's Avatar
not worth the effort IMO.
Old Apr 20, 2007 | 04:30 PM
86toysr5's Avatar
it would b time comsuming on the 2.7 the starter and battery are on the drivers side...and the front driveshaft is on the drivers side....intake on the left and exhaust on the passenger side.....no distributor it has coil packs
Old Apr 20, 2007 | 04:32 PM
90_yota's Avatar
thanks guys,i did'nt look at the 98 real close but it did seem like it would be more work than its worth.
Old Apr 20, 2007 | 04:33 PM
86toysr5's Avatar
dont get my wrong cause i just bought a 97 with the 2.7 and i love it. it has more get up and go the my 20r
Old Apr 20, 2007 | 04:45 PM
Sonofmayhem's Avatar
supercharge it! have a super quick fuel economical vehicle.
Old Apr 20, 2007 | 04:48 PM
90_yota's Avatar
i just sold a 1984 toyota pickup with a 350 chevy motor ,transmission and transfer case with 4:11 rears installed. that thing had the get up and go,lol. if i could get a super deal on a transfer case adaptor to adapt my case to a chevy tranny i would install a 4.3 or a 5.7 chevy motor in my 1990 toyota,lol.
Old Apr 20, 2007 | 05:12 PM
89silverpu's Avatar
why'd you sell the 84????
Old Apr 20, 2007 | 06:47 PM
CoedNaked's Avatar
So the transmission behind the 22RE won't bolt up to the 2.7?
Old Apr 20, 2007 | 08:34 PM
95RunnerSR5's Avatar
no but marlin crawler makes a bellhousing adapter for the R151 series transmissions!
Old Apr 22, 2007 | 07:53 PM
4Rocker's Avatar
Dont the 2.7s use a W series transmission? Im not positive, but wouldnt the w56 and xfer case with the pass drop from a 22re bolt up to the bellhousing of a 2.7?
Old Apr 23, 2007 | 09:24 AM
dcg9381's Avatar
I thought they would bolt up with the original behousing from the 2.7.
The 2.7 is more efficient, puts out better power, and has aftermarket forced induction kits available...
Old Apr 23, 2007 | 10:20 AM
pat161's Avatar
The 2.7's use the W59 transmission. Whether it will bolt to a W56 I don't know.
Old Apr 23, 2007 | 01:09 PM
Flash319's Avatar
Again why bother. The 22RE is the best engine ever made!!!! Just because it is newer does not make it better. MHO
Old Apr 23, 2007 | 02:19 PM
dcg9381's Avatar
Hard to beat a design that came out of 1970, eh?
2.7 does have a power advantage and is a significantly more efficient design... As stated above, I believe it will bolt up with a bellhousing change.
I've seen one aftermarket turbo report on it. The dyno was over 300hp.. Not sure if that was pump gas.
I like the 22R series also, but there are limits to 8 valve heads...
Old Apr 23, 2007 | 02:21 PM
4Rocker's Avatar
Does anyone know if the 22R/22RE motor mounts are the same distance from the end of the bellhousing as those of the 3RZ? That would be a nice swap to get a more powerful toyota 4cyl in the older trucks.
Old Apr 23, 2007 | 02:42 PM
fthertime666's Avatar
the 2.7 bellhousing bolts up to the 22re manual tranny. Marlins board has a lot of info about it, I belive his son has done a bunch of them.
the 2.7 is capable of over 1000 hp def. something to think about, and it would still be a toy 4cyl
Old Apr 23, 2007 | 03:13 PM
90_yota's Avatar
do you have a link to this Marlins board or where can i read it?
Old Apr 23, 2007 | 03:17 PM
90_yota's Avatar
nevermind i found it.thanks alot
Old Apr 24, 2007 | 05:19 AM
Flash319's Avatar
If you look at horsepower as your basis for a good engine then the 22re is not that good. It does have a very good torque curve for a truck though. I will agree that 8 valve's has its limitations and I think it would be even better if it where 16V. But the durability and design of these engines for trucks is awsome. The only reason that they use a 2.7 now is that they need a cross platform 4 cylinder engine for all their vehicals. The 2.7 is a front wheel drive designed car engine. Intake and exhaust on the same side. I bet it is a good engine but I like the engineering of the 22re.
Sorry for the highjack, I will shut up now
