22r with headers leaking aroud water pump and black AND Grey smoke video
Old Jul 15, 2013 | 12:09 PM
TeamCraigslistRacing's Avatar
[YOUTUBE]
[/YOUTUBE]
Old Jul 15, 2013 | 12:29 PM
gigatech88's Avatar
Can you re post the link? I get invalid reqUest when I try and view it.
Old Jul 15, 2013 | 12:34 PM
here u go man sorry let me know if this works
Old Jul 15, 2013 | 12:35 PM
try 3
Old Jul 15, 2013 | 12:38 PM
gigatech88's Avatar
Alright that Worked. Do you have any pictures of the leaking area? That's A Lot of smoke.
Old Jul 15, 2013 | 12:40 PM
I bought it the other day there was a engine swap done but they got frustrated when they fired it and the water pump was leaking so it sat there for 6 mounts ...I bought the truck trying to trouble shoot the problems also just pulled the plugs they are fouling black ...so im guessing she is running rich???
Old Jul 15, 2013 | 12:43 PM
gigatech88's Avatar
I would go over the engine. Electrical/vacuum and such. Where is the wp leaking from?
Old Jul 15, 2013 | 12:49 PM
gigatech88's Avatar
O yes black plugs. Most likely running rich. Are the plugs wet or dry?
Old Jul 15, 2013 | 07:58 PM
heres a pic of the plugs
http://imageshack.us/photo/my-images/20/7zuj.jpg/
Old Jul 16, 2013 | 10:46 AM
ok so not only is it leaking out the water pump it also appears to be coming out around the intake manifold ??
Old Jul 16, 2013 | 11:01 AM
Smilemon's Avatar
I'd quit running it till you get some leaks plugged up. Does your oil look okay?
Drain your radiator, pull off the water pump, replace the gaskets and get it bolted back on. Change your oil, fill up your coolant again, and see if it's still blowing white. Maybe the PO dropped a bad motor into your truck. I hope your headgasket is still in one piece.
Can always give it a seafoam treatment as well, but wait until you've plugged your leaks to start pouring chemicals into your fuel.
Old Jul 20, 2013 | 12:24 PM
Question
Ok so here's where im at now..i found 3 leaks and so far have managed seal 2 of them. one being the water pump the other a hose.im having a few problems with the metal tube under the intake .trying to find a o ring that fits it.
can Over-retarded ignition timing cause grey are white smoke ?
Old Jul 20, 2013 | 12:28 PM
gigatech88's Avatar
It's supposed to be a green high temp green o ring. Screw that. Rtv an a regular o ring works for me. If that part isn't leaking don't touch it.
O to answer your question . No. I can't think of a single way it would cause. Smoke. I've been drinking for hours so I very well could be wrong. But I don't think so
Old Jul 20, 2013 | 12:31 PM
Question
ok but do u know if Over-retarded ignition timing cause grey are white smoke ?
Old Jul 20, 2013 | 12:34 PM
I just picked up a leakdown test kit ..so hopefully that should tell me more info
Old Jul 20, 2013 | 12:37 PM
gigatech88's Avatar
Sorry. My sentences made no sense. No retarded ignition wouldnt cause smoke
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87blyota
Jul 10, 2015 04:31 AM
Avenged
Jul 9, 2015 07:55 AM
