2 PCV's on 22RE?
2 PCV's on 22RE?
I've been getting confused as to whick one is the PCV hose. Here's a pic of my 22RE, is it the one closest to the oil filler cap in pic1 or the one towards the back by the red connector pic2?
1)
2)
I'm going to try seafoaming in the near future and don't want to dump it down the wrong one and I will also replace it if it doesn't rattle.
1)
2)
oh my lord.. is that a heat shield over the engine? mine doesnt have one, but it has the bolt for it and the bolt hole for it. lol. seafoam and maybe some engine degreaser or brake cleaner on that.. make it look nice and shiny. wait, scratch engine degreaser. it takes the powdercoat off the metal. on mine, its the one right after the heat shield. not sure bout yours.
oh god, i hate that PCV. got a tip for ya. soak that new grommet in brake fluid for about 10 minutes. then put it in. will be hard to put in, but it will be super hard to crack and probably will never leak either.
pcv removal
The PCV the one at the back. Anyone know what the front one is? I'll look it up in the manual later.
Don't even bother trying to reuse the old gromet. It so hard it will chip. I cut away everything I could the set the remainig portion and old pvc alight with degreaser. Let it burn for a bit until its softened it up. Then pull it out with pliers. Won't come yet? More degreaser and cook it longer. The piece that fall into the valve cover can easily be fish out from the ledge right underneath the vslve.
A new pcv valve costs less than $5 I think from Lordco and the gromet was $2. I bet you could reuse the old pcv if you soaked it in solvent.
Access to my PCV is obstructed by panel thats rivetted into the valve cover, o I wasn't able to access it from below.
That tube next to the oil cap is the PCV return. The whole purpose to the PCV is to continuously burn the oil saturated air so that it doesn't pollute. It took me a while to find out what it was. My return hose was spewing oil so I replaced my PCV. The grommet was hard so it was awful to replace, so good luck.
It's a nightmare if it is hard from engine heat
