1st gen 4Runner wood paneling on interior
Old Nov 11, 2013 | 07:45 PM
YotaSnap's Avatar
I'm not sure if this is the appropriate forum topic , but here goes....
I have interior panels missing in the rear of my 87 runner and the doors have some very poor excuse of trim as well.
I went a got 1/4 inch sheet of white maple panel board and would like to customize this for my interior trim pieces.
There are a few ideas bouncing around in my head, but I'm interested to know what my fellow yotatechers think.
Old Nov 11, 2013 | 11:26 PM
jeffe's Avatar
Sounds good...
Old Nov 12, 2013 | 12:09 AM
dropzone's Avatar
Fossilized
Get some poster board to make your stencils and make some sawdust.
Old Nov 12, 2013 | 05:43 AM
islanti's Avatar
The easiest ay to get an accurate fit, especially if there are many rounded corners, is to make a template with cardboard. Just did this yesterday..
Old Nov 12, 2013 | 08:14 AM
YotaSnap's Avatar
Islanti those are some sharp looking edeges.
Old Nov 12, 2013 | 10:32 AM
Ijjiop's Avatar
Hey if you can take pictures of the progress, I am thinking of doing the same in my 92 yota in the next couple years. Would be very interesting to see how you do it and how it turns out! Good luck and looking forward to the results, which will be amazing!
Old Nov 12, 2013 | 11:21 AM
YotaSnap's Avatar
Sure. I'll post them in this thread. It will be a few days before I begin though. Thanks for the luck. I'm not a very good carpenter loo
Old Nov 12, 2013 | 12:33 PM
Ijjiop's Avatar
Just take your time and measure twice. If you think you may mess up cuts, leave extra on the cuts and then finish it by hand. I am not the best at that kind of stuff either and that is how I go about it, takes more time but if you measure twice and match it up as you go to make minor corrections you should come out okay.
Old Nov 12, 2013 | 01:25 PM
Stetson_md's Avatar
I think wood 1/2 or 3/4 door pannels stained dark would look pretty sweet they would be easier to make then full door pannels too
1/2
3/4
Full
Old Nov 12, 2013 | 05:34 PM
slacker's Avatar
we have the rears , if your interested ..
doors are NOT included , I know it's not wood .. but thought it might help
Old Nov 13, 2013 | 11:01 AM
Ijjiop's Avatar
The 3/4 looks real nice. I am def going that route when I do mine!
Old Nov 14, 2013 | 07:49 PM
YotaSnap's Avatar
I liked the idea of 1/4 in the back because it obviously will have more flex. Im not sure if flex would be 100% necessary, but we'll see.
I've decided that I will use some household foam under layment as insulation/sound eliminating material.
I like the look of the 3/4 on the doors. I think I might just do that since I won't have enough maple for everything.
Not so sure how I will do the rear end driver side being there's a fluid sack there.
I have winter prep stuff getting in the way of getting this stuff done right now. Maybe tomorrow.
Old Nov 14, 2013 | 07:51 PM
YotaSnap's Avatar
How much are these?
Old Nov 15, 2013 | 06:03 AM
Stetson_md's Avatar
Ok just to clarify 1/2 3/4 and full where door panel styles not wood thickness sorry if i confused you
Old Nov 15, 2013 | 09:02 AM
YotaSnap's Avatar
Yeah I realized that the second time I looked at the pictures. I still say the 3/4 since I have the speakers.
Old Nov 15, 2013 | 11:43 AM
Stetson_md's Avatar
3/4 is the way I went when i made my dp's also. just pay close attention to the bottom of the dp mine where to big after the first try and I couldn't close my door all the way
Old Nov 16, 2013 | 07:23 PM
YotaSnap's Avatar
What did you have to do to fix that?
Old Nov 16, 2013 | 07:25 PM
YotaSnap's Avatar
I still plan on doing this project, I just picked up two more trucks today. One is an 89 pick up with a 22re that needs a rear main seal and one is a parts car. I got them both for $1,400 and I'm feeling pretty good.
Old Nov 24, 2013 | 10:12 PM
YotaSnap's Avatar
I started on the door panels tonight and so far it has gone rather well.
So here is what the door panel looks like on the under side. There is insulation foam that really got in my way when doing the outline, so if you do it this way, I suggest cleaning that all off first.Name:  9a8be4a6-3ad2-4979-b6fa-6516fcc12878_zps751dbeb3.jpg
Also, you can see the blue plastic film at the top is on and it's in the way in my opinion. I just removed the whole red cover.
The rounded corner by the speaker was already damaged which is part of the reason I am doing this. It went back in to place well enough to do a stencil.
I'm a bit concerned that my jig saw wont give me the clean and sharp cuts I am after so I'm wondering if I should just cut wide and use a rasp/sandpaper to smoothen out the edges.
Anyhow, that's where I am as for tonight. And with cleanup time included it only took about 45 minutes to outline for both doors.
Old Nov 25, 2013 | 03:01 PM
Stetson_md's Avatar
Sorry for the delay all I did wascut/ file more off the bottom. Didnt have and old panel to use as a template
No matter what saw you use youll need to file sand or route the edges.
Also you probably won't notice if if it undersized
