1st gen 4runner rear disc brake install
Old Nov 8, 2015 | 06:48 PM
  #61
anndel's Avatar
Looks great man, congrats on an awesome project.
Old Nov 8, 2015 | 07:27 PM
  #62
DemonRunner's Avatar
I used the straight axle setup since I already had new calipers and rotors. Then got the brackets, spacers ,lugs , hardware and a new master from low range off road.Make sure you remove the lspv and block off the return line from the block at the right front wheel. I ran a new line from the block that goes to the rear the all the way back to the rear hose . Used proportioning and fittings from summit, installed right off the master. While your back there do the rear seals and wheel bearings. Bottom picture shows a tool I made to remove the axles from the backing plate
Old Nov 9, 2015 | 07:38 AM
  #63
boogiewoogie's Avatar
if u have 4 or 3 link suspension u can retain the factory ebrake using mustang calipers. u can still use them with leaf springs too just the ebrake isnt possible too hook up due to clearence
Old Nov 21, 2015 | 09:34 AM
  #64
jordanhere123's Avatar
What rotor can I use on the rear of my truck that will fit onto the hub and work with my sfa calipers? I have sfa rotors but the inside diameter is too small and wont go on the hub
Old Nov 21, 2015 | 02:40 PM
  #65
Brakes
The brackets/kit i used came from Lowrange , it came with the round spacers shown in my above post pictures . You put the spacer on the back side of the axle flange then the sfa rotor on next then press the studs threw them all. Uses the sfa calipers . So if you need to change a rotor in the future you will have to pull the axle and press the studs out.
Old Nov 22, 2015 | 01:28 PM
  #66
u can cut the rotors to a smaller size of the hub to fit too. theres a youtube video of it somewhere where they did that and it worked well
Old Nov 24, 2015 | 06:54 PM
  #67
I got mine all finished up today. Working great so far. Left the stock proportioning valve. Fronts lock up before rear.
AustinTaco
Aug 22, 2022 10:45 AM
Team420
Jan 12, 2021 04:57 PM
Niameyrider
Jun 25, 2015 05:50 AM
Leonel
Jun 13, 2002 02:42 PM
