1995 4runner - with 4" lift. Rear shocks help please
I bought the 4runner, it already had 4" lift kit, is on 33x12.5" tires. I believe the shocks are bad, I suspect the rear ones. Obviously the stock shocks will not fit. Looks like the mounts were not modified, just longer shocks that are rust-filth I can't read anything off them. Does anyone know which ones I can order?
All of these will work for the rear lifted 3-4 inches 90-95 4runner
H7024 skyjacker hydro
N8024 skyjacker nitro
326513 es3000 procomp hydro
926513 es9000 procomp nitro
My truck hits a bump or something at like 65mph, and then it starts rocking left to right. Really annoying I have to slow down to shake it off. I did not see anything at first look, we checked for missing bolts that feel out in the lift kit - did not see any. 2 wheel bearings I have to replace. I do not know if my sway bar can cause this either, bushings shot up on those on the front. I do not like to blindly replace shocks without actually knowing if they are busted, but I feel like I am running out of options.
What kind of 4" lift are we talking about? Solid axle?
Bump steer can come from several different sources, but check for any loose joints / bearings / bushings in the front end first.
Thank you for advice. I will do that before spending more money on guess items.
Rear coil springs, front independent suspension. I do not know anything about the different lift kits or brand names to say what kind. There are steel shackles and brackets that extend the front and back. Some straps are bolted to the rear and frame to stop it from articulating too far.
Quinn's87RE
08-08-2019 09:54 AM
904x4Runner
03-06-2008 01:52 PM
cvlighthouse
02-21-2007 02:14 PM
