1993 Toy 4x4 V6 SR5 Truck probs...
Old May 7, 2007 | 07:14 AM
tdbear30's Avatar
I'm experiencing varying idle speeds, usually a little low, but still it varys. The truck sounds as though it sputters a bit while at speed, but not terribly bad, and there is a little hesitation when you start it up. It's becoming progressively worse.
I cleaned the throttle body, and it still does it. I'm guessing that the TPS is bad and someone suggested it could be a idle air control valve. This is driving me crazy, any suggestions would be great...
Old May 7, 2007 | 08:16 PM
pruney81's Avatar
Fuel Filter maybe?
Old May 9, 2007 | 03:56 AM
tdbear30's Avatar
Fuel...
It's getting terrible mileage too.
Old May 9, 2007 | 08:34 AM
4Runner1988's Avatar
I am having the same issues. I need to clean the TB....then check the TPS. I also checked every Vacum hose on the thing. One little break or leak can affect these things pretty good if its the right line! Mine has over 205,xxx on it....so I suspect I'll be replaceing vacum lines more often now....!
my .02 worth....at least....
Old May 9, 2007 | 08:39 AM
bruizer's Avatar
miracles
A major tune up does wonders......
Old May 18, 2007 | 03:25 AM
tdbear30's Avatar
Ends up compression...
...was low on #3 and #1, adjusted valve clearance and replaced shims.$778.50 later by First Team Toyota and my rear was sore, but my truck runs normal again. Dealerships are thiefs!
Old May 18, 2007 | 03:36 AM
TNRabbit's Avatar
A valve adjustment for almost $800? HOLY EFFING COW.
Old May 18, 2007 | 04:02 AM
04 Rocko Taco's Avatar
Ouch? Did they at least use KY? I hope your rear gets better soon.
justdifferentials
14
Jun 11, 2017 08:36 PM
Zach_trun
Nov 17, 2015 07:56 AM
Ott47
Sep 14, 2015 12:09 PM
mordell
Sep 12, 2015 10:13 AM
Badfish740
Sep 4, 2015 04:21 AM
