1993 3vze clutch job. (bakersfield)
Old Nov 7, 2010 | 10:39 AM
Squeebs's Avatar
I'm such a nice guy that i told my buddy id help him change his clutch.
93, 3.slow, 4x4, r150f trans.
Got the drive lines off, sway bar is gone, exhaust brace is off, shifters are out,
pretty much, we just need to get the starter off and we can start pulling the tranny bolts.
Any tricks to getting the starter off? We are kind of looking around like deer at headlights.
So uh... Advice? Or anyone in bakersfield wanna come play?
Old Nov 7, 2010 | 10:43 AM
xxxtreme22r's Avatar
you got to take it out from the passenger fenderwell, might have to move some brake lines and wires around to fit it out, but it comes out that hole. Just like on the first gens. Try to take it out any other way you will continue to look like this:
Old Nov 7, 2010 | 07:21 PM
gary96360's Avatar
im pretty sure i unbolted the starter from the front of the truck when i dropped my tranny. i have a 3 inch body lift so that made the whole job much easier
Old Nov 7, 2010 | 08:18 PM
vital22re's Avatar
totally a bro
there is a panel that you can remove 4 bolts... in the fender well on the passenger side. It makes access a little easier. Also make sure you disconnect the battery.
Old Nov 8, 2010 | 03:45 PM
REDYOTA's Avatar
take off the steering stabilizer and get about 2 foot of extensions to hit the front bolt
then hit the rear bolt disconnect clip
take all the panels out of the passenger fender well and maybe the tire and get ready to fish move wiggle cuss and repeat
perhaps take it apart and check the contacts while you have it out.
Old Nov 8, 2010 | 06:38 PM
Squeebs's Avatar
All apart... tranny only comes about 2.5" away from the motor though.
I hope it is something catastrophic in the tranny so i can just walk away.
Why wont it come out?
Tranny and t case dont need to be in neutral or anything do they?
Old Nov 8, 2010 | 08:10 PM
HupDogDaddy's Avatar
Did you remember to take off the shifters?
SOrry -- just being obvious
Old Nov 8, 2010 | 08:24 PM
dntsdad's Avatar
Exactly what I was thinking.
Also, disconnect the battery of you may be welding with that starter wire.
Old Nov 8, 2010 | 08:50 PM
Tubbyfatty's Avatar
I bet the top of the tranny is hitting the shifter hole in the floor board. Happened to me, I just bent it up a little.
Old Nov 17, 2010 | 06:09 PM
So what happened ??? Did you ever get it out?? we need pictures so we can tell you what your doing wrong
Old Nov 17, 2010 | 06:59 PM
Squeebs's Avatar
bellhousing is hitting the firewall.
Gonna jack the motor up a little bit and yank her out this weekend.
My jerkoff friend never mentioned that his buddy grant was a toyota master mechanic in the mid 90s before he became a crane operator.
Old Nov 17, 2010 | 07:20 PM
just call me smithy's Avatar
have you removed the dust shield?
Old Nov 18, 2010 | 07:26 AM
If it still has the factory exhaust crossover, you have to give the tranny a little twist to the driver side and it will clear.
jasonty
41
Dec 23, 2018 01:00 PM
norcal98
Aug 10, 2015 06:20 AM
teknovls
Aug 9, 2015 12:37 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
PlayAwhile
Jul 20, 2015 11:36 AM
