1992 3.0 hc (ppm) way too high
Old Aug 10, 2012 | 01:20 PM
Evan Mansfield's Avatar
1992 ext cab 4x4 3.0
hc (ppm) idle limit is 400
truck is running at 1459
passed cruise but idle is way too high
any ideas?
Old Aug 10, 2012 | 02:42 PM
Dirt Driver's Avatar
What were all the other readings? What state are you in? Do you have a cat converter? Is the truck stock? Need more info.
Old Aug 10, 2012 | 04:12 PM
scope103's Avatar
You're idling way too rich. Run the check procedure (from the diagnostic connector) of the O2 sensor. If it works at speed but not at idle, you could have a problem in the heater circuit (though that should throw a code). You could have an exhaust leak (air mixed in exhaust makes it look lean to O2 sensor, ECM incorrectly moves rich).
The other readings would be helpful. http://www.autoshop101.com/ / Technical Articles / Emission analysis
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
ZONAYODA
Jul 13, 2015 07:17 PM
tobylab
Jul 12, 2015 12:53 PM
