1990 pickup 3.4 swap radiator overflow mount issue
Old Sep 30, 2015 | 03:38 PM
scott90's Avatar
I have a 1990 toyota pickup extra cab..it use to have a 3.0 from a 1994 toyota pickup but I decided to finally swap it. The only real issue I've ran into is where everyone usually just flips the bracket on the radiator overflow and just remounts it to the core support I don't have the clearance to do it. My power steering cooler lines are in the way which doesn't alow me to drop the tank down far enough to mount it.. Anybody run into this issue? I've tried searching but can't find anything.
Old Sep 30, 2015 | 11:37 PM
wyoming9's Avatar
Red face
Maybe your truck is different but on my92 4Runner
I have the over flow sitting in front of the battery box the cooler lines run parallel behind the radiator above the lower hose.
I did not have any clearance problems
Then my washer fluid tank sits behind the battery in front of the charcoal canister.
Old Oct 1, 2015 | 02:49 AM
scott90's Avatar
Here's a photo of my setup,there's not enough room between those lines and the battery
Old Oct 1, 2015 | 12:01 PM
wyoming9's Avatar
Red face
Right about where the steel lines come out of the rubber is where I mounted the cooler .
Giving me plenty of room
This is a swap so you can move things around to make things work.
Old Oct 1, 2015 | 06:55 PM
scott90's Avatar
Hmm I'll have to look into that and see what I can move around do you have a pic of yours I can see for reference?
Old Oct 1, 2015 | 10:19 PM
wyoming9's Avatar
Red face
I will try to remember and take one .
If it is not raining to hard
Old Oct 4, 2015 | 09:05 AM
wyoming9's Avatar
Red face
My pictures seem to be to big to post .
If you send me a PM with your email address I will be glad to send you some.
Old Oct 4, 2015 | 09:21 AM
wyoming9's Avatar
Red face
Try again
Attached Thumbnails 1990 pickup 3.4 swap radiator overflow mount issue-006.jpg   1990 pickup 3.4 swap radiator overflow mount issue-007.jpg   1990 pickup 3.4 swap radiator overflow mount issue-008.jpg
bradstyle
Jun 19, 2018 03:15 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
Edionne13
Jun 21, 2015 11:37 PM
duckhead
3.4 Swaps
7
Jun 18, 2015 06:54 AM
