Last edit by: IB Advertising
Browse all: Brake Guides
- Toyota 4Runner 1984-1995 How to Replace Brake Pads and Rotors
Step by step instructions for do-it-yourself repairs
1990 4X4 Front rotor replacement
Front Wheel Bearing preload - torque nut with no socket
Some of us are "pros" are without a socket, and the fish scale drag is a good finial test. But get it right first with vicegrips locked across the nut; then vicegrip a 1/2 extension to the GRIPS on the nut - VOILA ! - YOU CAN TORQUE CORRECTLY THE FIRST PRELOAD 43LBS; THEN AFTER THE ALTERNATE CYCLES OF LEFT AND RIGHT TURNING OF THE HUB; LOOSENING REPEATING; TIGHTENING AGAIN TO 43LBS; ROTATE; LOOSEN THEN ROTATE; FINIAL TIGHTEN TO 21LBS.
FOLD AVAILABLE TABS OF THE LOCK-WASHER TO PIN THE PRELOAD TORQUE; TORQUE THE LOCK NUT TO 43 LBS - WORKED PERFECT.
Late year 1989 pickup 4cylinder ST - i did the timing chain replacement with head on - make sure you pull the pan, the pieces of the rail are not just at the bottom, but can glue and accumulate upon the oil pickup intake screen - lowering oil flow and pressure,
#25
Back in the day I've done hundreds of wheel bearings on log trucks by feel no fancy tools they average 10-12 thousand miles a month and the only failures were older bearings or lube problems not preload related
voiddweller
19
05-02-2016 09:10 PM
YotaGreenhorn
06-27-2015 07:00 AM
