1990 4Runner window problem fix
This is my first post so I figure I should do something useful
I had a problem with my rear window not wanting to roll down all the time (only when it felt like it) for about a year. It finally stopped working all together before I decided to do something about it. It took me a while to track down the problem but, long story short, it ended up being the relays in the Window Control Unit. I took it out and removed the plastic cover. Looks something like this-
Then I de-soldered and removed the relays.
I went down to the local RadioShack and picked me up four of these-
SPDT
9VDC
Mini Relay
SPDT
9VDC
Mini Relay
I think it's pretty close to this one-
http://www.radioshack.com/product/in...ductId=2049716
This is the only one I could find online that might work. It's 7-9VDC and the ones I used are 9VDC. They are the same amperage rating so if the posts are the same they should work.
The pics I have are kinda crap (obviously) and the one I took of the location was really bad. I took them back in the day when I first got my Ipod touch. My bad. So I tried googling it and I stumbled on this little thread-Rear window relay fix- 1990 4Runner
Well I wish I would have found this back in the day when I was trying to fix my rear window
The pic Matt16 has is useful. You can see that it's kinda behind the little storage compartment on the driver's side. It's on the back side of inner body panel and looks like this-
voiddweller
19
May 2, 2016 09:10 PM
infinityisfive
Jun 16, 2015 06:51 PM
