1990 4runner chop and bob.
Old Feb 28, 2008 | 02:50 PM
AZ4ME's Avatar
Originally Posted by Elvota
Wow... chop and bob indeed.
Looks pretty good. Do you plan to close in the back or just leave it open?
Did the back end come up just because of all the weight taken off?
Are you ready Steve? I have to put in my Longs this weekend, but I could come over after that.
Old Feb 28, 2008 | 03:13 PM
Elvota's Avatar
It's gonna have to happen sooner than later. Every time I see a thread like this I get re-inspired.
Old Feb 28, 2008 | 04:49 PM
run4her's Avatar
My plans came from me busting out my window and getting angry.
Old Feb 28, 2008 | 05:58 PM
olharleyman's Avatar
Originally Posted by run4her
I am re using the stock tailgate and rear window track, I may make some sort of manual slider for the rear window but i am having a soft top with tonna cover made on satuday for until i winish making all the walls for the inside and making the mount for the winch. Just remember it is still in progress. The welds will be finished and all. LOL
I am real interested in seeing the window tracks back inplace thats the one thing that has eluded me on my plan to do the chop myself.
Old Feb 29, 2008 | 09:38 AM
  #25
run4her's Avatar
I am having a hard time stripping out all the extra sheet metal for the window track. It is like 4 layers thick so I cant cut it streight to lne up with where i already cut. I was a little scared to do it but the chop was easy. I had that done in like 3 hours. The bobb is not finished and i have about 8 hours into it. I could have done it faster but i have to quit around 3 every morning cause i get up at 8:30 and i have to get it to a point where i can drive it the next day.
Old Mar 2, 2008 | 05:34 PM
  #26
run4her's Avatar
I have now tacked on the rear window track.
Old Mar 2, 2008 | 06:04 PM
  #27
312necro213's Avatar
I am inspired... This summer this is taking place for me... Im gonna go with an open bed and a square back, how did you protect your carpet? Or did you just remove it all?
Old Mar 2, 2008 | 06:54 PM
  #28
fillsrunner4's Avatar
Question? Before you cut the back did the truck sit level and after the cut it raised like this.
I plan on doing similar work on mine and am contemplating removing a leaf from my leaf packs front and rear to accomidate and add maybe a bit longer shackle in the rear.
Looks really good I think you took the perfect amount off
Old Mar 3, 2008 | 03:51 PM
  #29
run4her's Avatar
I have coils and when i cut off all that weight i gained about 3" of lift lol. I am buying my sas kit tonight and will lift the front to match. Then i will extend the rear outer links and move my rearend back a little. Ps. My camera is charging will post pics in a couple.
Old Mar 3, 2008 | 03:52 PM
  #30
run4her's Avatar
I removed it.
Old Mar 3, 2008 | 03:54 PM
  #31
I wonder if my leafs will yeld such big gains from the cut Ill have to see I guess. I would like to keep my 4runner low becuase of the top weight so I bet Im going to have to remove a pack from the springs. Cant wait to see some more pics
Old Mar 3, 2008 | 04:01 PM
  #32
run4her's Avatar
When u cut the top u lose 250-300 pounds off the top so that helps too.
Old Mar 3, 2008 | 04:10 PM
  #33
run4her's Avatar
Sorry not the best pics cause its raining hard.
Old Mar 3, 2008 | 04:33 PM
  #34
Yotaholic's Avatar
Holy hell man thats wild !! Awesome work cant wait to see more of this beast . Subscribed
Old Mar 3, 2008 | 04:39 PM
  #35
Elvota's Avatar
So you ended up grafting back on the original window frame? I think that's a pretty good way to go.
I have always wanted to chop, but keep the ability to lower the rear glass by re-using the original tailgate. But I guess the wheel wells are in the way.
What's you plan? Fixed glass, something else?
Old Mar 3, 2008 | 04:58 PM
  #36
WCorbett's Avatar
you guys really are amazed aren't you lol. It is deffinatly sick thats for sure, I plan on it down the road some time. buuut:
http://www.pirate4x4.com/forum/showt...t=4runner+chop
And the reason you can cut and weld the back corner right back on is because both vertical diagonals on the rear side windows are parrallel.
Old Mar 3, 2008 | 05:08 PM
  #37
It is posible to mod in the roll down window. That is if you dont care it only goes down a few inches What about maybe a plexi window or similar material with hinges to make it fold down? That would be cool and I think I just gave myself an idea for mine
Old Mar 3, 2008 | 05:21 PM
  #38
Chrisnxl185's Avatar
has anyone thought about cutting the top off and keeping it as a hard top? That way you could run a soft top in the summer and have a hard top for the winter. If i ever had the courage, thats what i would do.
Old Mar 3, 2008 | 05:45 PM
  #39
Elvota's Avatar
Originally Posted by Chrisnxl185
Has anyone thought about cutting the top off and keeping it as a hard top?
Mossyrocks tried that... but the top is so heavy, it's hard to mess with. I think he was using a forklift, but dropped it. That was the end of the removable top experiment.
Old Mar 3, 2008 | 06:08 PM
  #40
ya but his was a 3rd gen. so it had the huge tailgate attached.
Is that top part really that heavy? I couldn't be any heavier than the 1st gen removable tops right?
