1989 toyota pickup LH tail light not working
Old Dec 6, 2017 | 09:52 PM
Radchadtrinidad's Avatar
been having this issue where my left hand tail light does not work, but my LH brake light works. rather than checking my LED bulb, socket etc, i probed the ground and power at the body side of the harness and ended up with 5 volts (LH). i then tested my RH tail light and got the expected 12v. sounds like split wire? or a relay? yes my dash lights and every other front light work.
can put in more information or pictures if needed.
Old Dec 7, 2017 | 06:43 AM
92ehatch's Avatar
You can determine which side your loss is on. The two wires feeding the bulb, you said have 5 volts instead of 12. Is that 5v from 1 wire to the other ? What about from each wire to ground? If you get 12v from the hot side to chassis ground, then you have a poor ground wire to the bulb. If you only get 5v to chassis ground then you have a bad power wire. Once you figure out which wire, trace that bad boy back until you find the point where the voltage loss is occurring.
Old Dec 7, 2017 | 07:43 AM
RAD4Runner's Avatar
Like 92ehatch says above.
Yes, a picture paints a thousand words.
There are 2 tail lights; one by itself, the other sharing ground with the brake light in one bulb.
Exactly which one are we talking about?
If you post pictures of the socket and the bulb, then we (who may be thousands of miles away) will see what you are working with.
Indicate in pictures what wire color goes to each terminal/contact.
Old Dec 7, 2017 | 08:09 AM
scope103's Avatar
Be careful measuring to "chassis ground." On my '94, the bed (where the taillights are mounted) is INSULATED from chassis ground (that's why there is a separate white-black wire to provide ground). I believe the electrical insulation is just secondary to vibration mounting, but the result is the same.
Old Dec 10, 2017 | 01:54 PM
okay guys so heres what i found. i was getting 5V to my left taillights as said. i wiggled my harness around where my bed is and suddenly got voltage spikes. i then untaped the loom and found the split wire i thought was present. fixed it and everything works! thanks for the help guys.
mudsicle
Aug 21, 2015 10:51 PM
Volnychev
Apr 17, 2014 01:40 AM
shawnshawn
Oct 9, 2012 07:00 AM
reaj
Oct 9, 2011 10:13 PM
shadowschild
Jun 21, 2008 09:54 PM
