1989 toyota pickup auto transmission
Hello, My truck drives and shifts fine. while driving i can hit the a/c button and with in a few minutes the transmission is not working. it acts like it is in neutral. pull over to side of road put in park shut off the engine and turn off the a/c, back to normal. Can drive it without any issues until I hit the a/c button, same issue. Any kind of help or information would be greatly appreciated. Thank you
Unhook the AC idle up valve and see if it still does it. Its one of the three little vacuum valves mounted in the engine bay above the passenger side fender. The truck will run without it. It just may idle slower while the compressor clutch is engaged. Should just be able to disconnect the electrical connector on it. Let us know.
FS[PacNorWest]: 1988 Toyota Pickup 4x4 Long Travel - Seattle, WA - $6500
96taco4x4
Feb 6, 2020 05:16 PM
4Nmissile
Nov 14, 2016 08:54 AM
joekerr1@gmail.com
Aug 18, 2016 04:57 PM
