1986 4runner 22re replaced tps crazy rough idle
Old 08-04-2013, 06:04 AM
moosebreck's Avatar
So the 86 4runner sr5 has been broken down for 3 days now and finally got a throttle position sensor installed due to rough/low idle no power prior to breaking down. after putting in the new tps car still will not turn over unless safety cancel is pushed while trying to start her up. i hear ignition relay click, and hear no grinding of ignition when trying to start her up. battery died due to trying to start so she will only start when a jump pack is attached to battery. when she does start up car revs and drops revs and drops, pushing clutch/gas in has no result. any answers would be greatly appreciated.
Old 08-04-2013, 12:36 PM
KBaz's Avatar
When you try to start it do you have the clutch pushed all the way down? Did you adjust the tps once you put on the throttle body?
Yont283
09-23-2022 08:06 PM
DacodaYota
09-02-2015 02:13 PM
Alex Bessinger
06-28-2015 10:05 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
bobbybouche
06-18-2015 10:22 AM
Quick Reply: 1986 4runner 22re replaced tps crazy rough idle
