10W30 or 40?
Old Apr 10, 2007 | 05:07 PM
rdharper's Avatar
Originally Posted by Yota82
Fix the problem and run 10W-30. Valve seals?
No offense but that is what is known as the placebo effect. It just soesn't make sense. Better gas milage and more hp with thicker oil? Highly unlikely.
Of course you are probably right... only thing that might happen in some cases is, if the rings are worn, you might reduce blow-bye and increase compression a bit. Dunno.
Old Apr 10, 2007 | 05:49 PM
Mark in MD's Avatar
Originally Posted by Belize Off Road Team
but i have talk to the locals down here and they run there little gas Toyota's with 20W 50 and have never had to replace anything. And the Toyota's down here have an average mileage of 300, 000k +. My friend down here has a 1980 Toyota Pick-Up 2WD regular cab etc. and all he has run for the last 10 years is 20W 50, i did my research before switching. Thanks for your concern though Mark in MD
You're welcome. Hope it works out for you.
Old Sep 1, 2010 | 07:41 AM
Wiznich's Avatar
Well after reading this thread I'm still a bit unsure what Im going to do with my oil.
I have kind of a weird thing going on with my 3vz. I do a fair amount of driving on the interstate (3K @65mph) I've noticed this summer that after about 30-40 miles the oil pressure gauge goes from dead middle down around the 1st tick mark, no change in RPM....it just goes down.
My guess was ok i'm running 10-30 switch to 10-40 there has to be some sort of oil break down going on. Now all that really did is (while the engine is cooler) bring the needle slightly past dead center on the gauge, but it still drops to slightly above the 1st tick mark after 30-40mi, only slight improvement.
I was considering switching to a 5-50, but now with all the talk of possible damage to the top end not getting enough lubrication I'm hesitant. I'm planningon taking the 4runner(95) to Taos NM this weekend and I'd like to see some decent pressure on the gauge, then again as long as it's above the 1st tick that could be in spec.
What would you guys think? Long trip=5-50 or just leave the 10-40?
Old Sep 1, 2010 | 08:20 AM
blake.nemitz's Avatar
a synthetic oil will burn faster because of the molecular makeup of the molecules, in a syn they are in long chains and even a 20-50 will flow better than a 15-40 conventional oil, if you leak you will leak more with a synthetic, same with consuming it, my opinion is to run 15-40 rotella, its what i have been using for the last 3 years in my runner with over 200,000 miles engine is fine, you get better protection with a diesel oil, after us switched to ulsd additives were added to the oil to keep it clean and top end lubricated.
Old Sep 1, 2010 | 08:35 AM
  #25
Marc's Avatar
Stick with 10W-40. It's normal for the pressure to drop as the oil gets hot.
Old Sep 1, 2010 | 08:39 AM
  #26
Wiznich's Avatar
Thanks, yeah I would go with synthetic my 4runner just turned the 1/4 million mark and it has a rear main leak, it doesn't leak a lot but I still wouldn't chance it. I've read about people using the diesel oil, but I've never tried it so I guess it will be a good experiment. Thanks for your reply.
Old Sep 1, 2010 | 03:03 PM
  #27
greatskiiiier's Avatar
not ganna read through the whole thread but obviously everyone with a keyboard is an expert on motor oil, all I'm going to say is higher mileage motors benefit from thicker oil and unlike most of the people on here I actually have a close affiliation with the top brand of motor oil which I will not name in this post
Old Sep 1, 2010 | 03:13 PM
  #28
Mobil 1 High mileage, it has seal protection in it
Old Sep 1, 2010 | 07:18 PM
  #29
Wiznich's Avatar
Cool, thanks I think I might try and and find some Mobile 1 high mileage 10-40. There are really a lot of opinions on oil types. Thanks for the replies.
keithguts
Feb 15, 2012 11:46 AM
CoedNaked
Apr 15, 2008 08:18 PM
Charger92
May 24, 2006 05:43 PM
sandcrawler
Jun 10, 2005 06:34 AM
