1" coil spring spacer?
Old Aug 19, 2009 | 01:59 PM
nevermore1701's Avatar
I replaced my coil springs with Moog variables, and that helped a lot. Still a little low in the back though, and when I put the 33s on it got even more obvious. I think 1" higher would be just about perfect. I found some 1.5" spacers, anyone make 1"?
Old Aug 19, 2009 | 02:28 PM
Tubbyfatty's Avatar
Just get some 2'' spacers from 4crawler.com lol.
Old Aug 19, 2009 | 02:36 PM
I don't want 2", I want even.
Old Aug 19, 2009 | 02:56 PM
tc's Avatar
tc
I think that you will find you need to be slightly higher in the back for it to look "even" due to the different arch in the wheel openings
Old Aug 19, 2009 | 02:58 PM
YeloSub7's Avatar
I would go for the 1.5" always nice to be a little higher in the back for load. But as tc said, it might "look" even because of the wheelwell. I actually measured it once and I think the rear wheelwell is almost 1.5'' lower in the rear anyways. So depending on how you measured it you should be fine with the spacers you got. Good luck! Lets see some pics!
Old Aug 19, 2009 | 03:38 PM
FredTJ's Avatar
The only way to see if the vehicle sits "level" is to measure, say, the distance from the bottom of the rocker panel (under the door for the newb's) at the front, right behind the front wheel well opening, and then again at the rear, right in front of the rear wheel well opening.
Fred
Old Aug 19, 2009 | 04:14 PM
Very interesting. I just measured, and the front and rear rocker panels are within 1/8" of each other. It just looks saggy. Not sure what to do, since it's actually level I'd need new rear shocks if I got a 1.5" spacer, most likely. Might just leave it. Meh.
Old Aug 19, 2009 | 06:32 PM
FredTJ's Avatar
The reason that it looks saggy, as already mentioned, is because the front wheel wells are cut up higher in the body than the rear wheel wells. The eye tends to follow an imaginary line drawn from the top of the front wheel well to the top of the rear wheel well. Since the top of the front wheel well is higher, it appears that the rear is sitting lower, when it really isn't.
If you put 1 1/2" spacers in the rear you will need longer shocks or else you will lose 1 1/2" of rear axle droop. This is assuming that there is 1 1/2" of extension remaining in the shocks as they sit now, though there should be.
Fred
Old Aug 19, 2009 | 06:36 PM
That's what I figured. *headdesk*
Old Aug 19, 2009 | 06:39 PM
abecedarian's Avatar
If it's saggin 1.5" and 1.5" spacers make it level, likely the shocks are the right length to begin with. It's the springs muckin with you. The rear springs shrunk, not the shocks.
(wow it was hard not to do that with a scottish brogue)
Old Aug 19, 2009 | 06:45 PM
FredTJ's Avatar
However, it ain't sagg'n. He measured and it sits level
Fred
Old Aug 19, 2009 | 06:49 PM
Yeah, new springs leveled it out perfect, just doesn't look like it
Fred
Bet you did that with a British accent, right?
And you're right. 1/8" variance between the front and rear rockers is hardly something to sneeze at.
(that was irish)
Old Aug 19, 2009 | 06:53 PM
I'd guess less than 1/8" actually. It's actually dang near perfect, I just don't have a level long enough to confirm. Acording to my little 2" tube its perfect. I was quite surprised.
Old Aug 19, 2009 | 06:58 PM
FredTJ's Avatar
(that was irish)
Tried to mate. How'd it sound on your end of the line
I caught the Irish accent
Fred
Old Aug 19, 2009 | 07:22 PM
ah... and then you go under with the aussie accent, mate.
to nevermore1701- if the distance between the upper and lower shock mounts doesn't change, as in your compression / bump stops keep the axle from moving too far up, and the .. well the rear doesn't have droop stops, does it?...
meh... you should be fine.
punks_is_4x4
May 31, 2016 06:03 AM
choppe777
May 16, 2016 08:00 AM
_Nicco_
Sep 21, 2015 03:06 PM
JHalcyonM
Sep 14, 2015 01:10 AM
Aaron Logan
Sep 3, 2015 08:08 AM
