why does my 4runner not start in the cold outside but starts in the garage?
Old Nov 27, 2007 | 05:08 PM
bigt's Avatar
heres the question.. i have a parts truck that ran great... off this truck i have taken a cold start injector.. dirty but i cleaned it up and a cold start injector timer???
now my 4runner STARTS like a dream WHEN ITS PARKED IN THE GARAGE..
when i park in the drive way NO DICE.. it will crank and crank and crank and if i hold the gas down and smell gas for a few cranks then it might start to sputter and then finally get it to start... which is very bad... new plugs and wires are new..
which peice does yotatech think might be the issue??
Old Nov 27, 2007 | 05:11 PM
Ringmaster's Avatar
Cold start injector.
Old Nov 27, 2007 | 05:25 PM
bigt's Avatar
not the timer??
thanks thats and easier fix
Old Nov 27, 2007 | 05:45 PM
4Crawler's Avatar
The cold start time switch is what turns on the cold start injector. Check it out and make sure it is working properly (a factory service manual will have the test procedure). Also, might try the fuel pump test jumper:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Nov 28, 2007 | 04:53 AM
bigt's Avatar
ok so i am on the right track...hopefully it will continue to start in the garage till i can get into her on the weekend
Old Nov 28, 2007 | 05:16 AM
YotaJunky's Avatar
x2 on the cold start injector (CSI), or the wire to the CSI.
Team420
Jan 12, 2021 04:57 PM
voiddweller
19
May 2, 2016 09:10 PM
Cesarl74
Apr 23, 2016 06:07 PM
Badger62811
Jun 26, 2015 09:26 PM
jmc88runner
Jun 18, 2015 03:39 PM
