Whats the best performance mod?
Old Jan 3, 2009 | 10:00 AM
camo31_10.50's Avatar
yea..i say just get used to it..at the most, maybe do a cam and header..get your carb tuned JUST RIGHT..and your timing and you should be ok..make sure your gearing in your axles is right for the tires you are running..as in dont run 35's on 4.10's..you'll have NO POWER..lol.
i myself have realized that older model toyota pickups have no power..which makes them soooo reliable, if i ever have to do a motor swap...i'll probably go with either a 4.3V6, or a 3RZ-FE..probably the 4cyl..just to keep it toyota..that thing has loads of power..lol
Old Jan 3, 2009 | 10:32 AM
AZ89LONGBED's Avatar
You can always put in a properly-timed camshaft, but plan on spending around 200-300 if you do the work yourself.
I'd say a good tuneup is a start, then make sure your vacuum lines are not rotten.
Headers & exhaust, then maybe a head with oversized valves, advance valve timing 2 degrees, you will have MAYBE 25-30 more HP.
Old Jan 3, 2009 | 12:09 PM
farmerj's Avatar
the correct size tires or else make sure it's geared correctly.
Old Jan 4, 2009 | 12:18 PM
dub84's Avatar
im only runnin 235 cooper ST's so tire size is definitly not an issue
Old Jan 4, 2009 | 12:52 PM
  #25
Wardamneagle's Avatar
Originally Posted by 86tuning
$2500 for a few horsepower? Jeez for that amount of money you could swap in a much more powerful engine, or just buy a more powerful truck.
Maybe you could buy the truck but you won't get a nice engine for $2500.
Old Jan 4, 2009 | 01:14 PM
  #26
Matt16's Avatar
Driver
Old Jan 4, 2009 | 01:24 PM
  #27
86tuning's Avatar
That depends on who does the swap.
A 1uz engine, complete with wiring harness and all that jazz, runs about $1k from the local wreckers.
Of course, you'd need a bellhousing, headers, and a whole lot of work, but you'd end up with 300# of torque instead of 150#.
The $2500 on a few horsepower modifying the engine is not a good value.
IMO, modify the driver, not the engine. Do all the footwork mods before anything else. Tires, armour, lockers, winch, etc.
/10 cents/
TheBFA
Feb 15, 2020 06:55 AM
Iceman4193
Oct 16, 2015 10:50 AM
kbpickens
Oct 2, 2015 03:37 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
