What Tranny Do I Have?
Old Oct 2, 2005 | 11:43 PM
jimbo74's Avatar
my truck is special.... its an 85 4x2 and seems to have a bunch of parts peopel say it doesnt have... i have confirmed it has a g662 rear end, which is an 8" rear with 3.07 gears and 2 pinion.. engine is a 22r, late model.. the truck is a RWD truck only... so no transfercase.... the vin plate says w46, but that is a 4speed... my truck has a 5 spped... everywhere i have looked, i havent seen any mention of a 5 speed in a 4x2 that wasnt a 89+.... anyone know what model tranny i actually have? also i have looked through the pictures on marlins site, and the 89+ 5 speed doesnt look like the 5 speed my truck has
Old Oct 4, 2005 | 02:57 AM
jimbo74's Avatar
bump.
Old Oct 4, 2005 | 06:27 AM
TRunner's Avatar
wish I could help... I guess you don't know who did all the modifications on this rig huh?
Old Oct 4, 2005 | 07:33 PM
kyle_22r's Avatar
my best guess would be a 2wd W series 5 speed from either another pickup or a celica.
Old Oct 4, 2005 | 11:29 PM
jimbo74's Avatar
it doesnt look like the tranny of the 89-95 2wd pickup....
got any pictures of the celica one? is there a way visually to tell what model it is...
it isnt i dont know who did the modifications, it is that it does have a 5 speed and nowhere can i actually find info on what the tranny is.....
my truck might even lie and it could be original, everyone here on yotatech said i had a 7.5" rear end, but i kept digging and it is definately a 8" rear end sua single axle 5 lug axle
Old Oct 5, 2005 | 12:26 PM
kyle_22r's Avatar
any pics of your tranny? what's it look like? iron case, non removable bellhousing?
Old Oct 7, 2005 | 04:53 PM
squishy321's Avatar
My father had a 83 or 84 22re that was 2 wheel drive and had a 5spd, so it does exist. Im looking at a haynes manual and im thinking you either have a g57,g58 (2wd versions), the 84-86 carbs have a g52 but that is only 4 wheel drive. According to this book the only 2wd trannys are: the L series, g40, g57, and the g58. The Lseries is only 83 and earlier, and the g40 is 4 speed by the looks of it, so that only leaves the g57 and g58. I think the g58 is only available from 89-95 with add (true for 4wd at least) while non add 89-95 have the w series (4wd). So Finally that only leaves the g57. Now this is purely just know facts, looking at a haynes manual, and the process of elimination so i wouldnt take any of it as gospel. Try asking www.marlincrawler.com they only deal with 4wd but they are the best so they may know about 2wd.
Old Oct 7, 2005 | 05:56 PM
kyle_22r's Avatar
don't forget the 2wd W56, the W55, W50, and W45 trannies. i think the W50 may have had a cast iron case.
Old Oct 7, 2005 | 06:23 PM
jimbo74's Avatar
my truck vin plate says it has a w46, but my truck is definately a 5 speed and the w46 is a 4 speed
my tranny has an aluminum case
Old Oct 8, 2005 | 12:12 PM
squishy321's Avatar
Yeah i was just going by what the manual said, it didnt say that the w series was a 2wd but i guess it is. Im guessing you didnt always own this truck all along. My guess would be that someone took the 4 speed out and swapped in a similar era 2wd 5spd out of a 22re model because i know they had a 5spd. Once again ask marlincrawler.com they are the foremost expert in toyota 4wd trannys so they should know something about the 2wd
Old Oct 12, 2005 | 11:29 AM
jimbo74's Avatar
i have looked @ marlins site and done some comparison, and the tranny i have doesnt look anything like the 5 speed offered in any of the 4x2 trucks....
Old Oct 12, 2005 | 11:45 AM
jimbo74's Avatar
ok i take that back, it kinda looks liek the
thats probably what it is......
Old Oct 14, 2005 | 09:48 PM
jimbo74's Avatar
since my w56 is not original, what trucks did the w56 2wd come in? like modle years? lce has short throw shifter for the 4x2s from 89-95
Old Oct 15, 2005 | 01:43 PM
kyle_22r's Avatar
i think you're more likely to have a W55, should look similar to the W56. the W56 was only found in 4x4s and 1 ton 2wds.
Old Oct 22, 2005 | 02:30 AM
jimbo74's Avatar
how different is the w56 from the w55? why is no information avaialbe on the w55 (well that i have found anyways)
my truck is a 4x2, so that rules out being a 4x4 tranny..... the tranny i have does look liek the picture marlin has on their site showing a w56 2wd.... is there a way to idnetify it on the case?
Old Oct 25, 2005 | 11:04 PM
jimbo74's Avatar
and my truck needs a new tranny now... anyone got one?
also what trannies will bolt up to a 4x2 with a 22r?
Old Oct 25, 2005 | 11:22 PM
Rivalred's Avatar
Perfect time to make a 4x4.
Old Oct 25, 2005 | 11:26 PM
jimbo74's Avatar
yeah was kinda thinkign about that.... i would need a tcase, a tranny, a crossmember, and a driveshaft.....
and if the 4x2 tranny is too expensive, i might jsut do that...... gotta see where i can get the best price though, im going to do whatever i can as cheap as possible
Old Oct 25, 2005 | 11:42 PM
Rivalred's Avatar
Start looking around for a donor truck, I am sure there are a lot around. Would you have to covert your front brakes or front suspension at all? Solid axle or IFS?
Old Oct 26, 2005 | 01:16 AM
jimbo74's Avatar
ok so here is the tranny i actually have....... is this a w56 2wd? it looks like it to me....
and will a 4x4 w56 work on my truck if i swap the tailhousing instead of a tcase?
pic will be up in a minute, my host is down
