Valve lash settings
Old Feb 18, 2011 | 05:19 PM
LSUfan71's Avatar
Originally Posted by xxxtreme22r
torque spec on the valve cover I think is 20 inch pounds according to the TTB article.
I knew it was in-lbs, not many of us shade tree mechs have a torque wrench in in-lbs...
Old Feb 18, 2011 | 06:40 PM
xxxtreme22r's Avatar
IIRC when I did mine with an in-lb torque wrench it was about a half turn from finger tight with new grommets and a new valve cover gasket.
Old Mar 27, 2011 | 07:13 PM
LSUfan71's Avatar
Will gas leaking in the vacuum system cause extra noise, such as I described? I noticed a drop of gas from the AAP tube at the BVSV. I believe the AAP diaphragm was leaking, it was dry/stiff too. I replaced the AAP diaphragm and the BVSV plus some new vacuum tube. Then reset the lash settings to .007 & .009, now it purs like a kitten
88sasturbotoy
Jan 30, 2026 01:57 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
voiddweller
Jul 15, 2015 03:56 PM
cars-guy
Jul 11, 2015 07:51 PM
