Truck is shuddering at 30km/h?????
Old Aug 11, 2007 | 05:22 PM
Kirby's Avatar
Ok well I just got my truck rolling after a slight amount of work.
New frame, brakes, diffs, gears, new one piece drive shaft, 4" spring lift/shocks(pro-comp) and new 5.5" heavy shackles.
Now the problem I have is when the truck hits approx 30km/h(20 miles) it starts to shudder, but evens out and runs smooth once I get above 33ish. I am not sure if the rear shaft was balanced when I had it cut down an so am wondering if that?
Or if my rear diff/driveshaft axle angle is too straight. With the shims that came with the kit the drive shaft/diff angle is pretty close to straight... could this be it?
Or if anybody has any other brilliant ideas please let me know, I wanna take this puppy wheeling next week.
Kirby
Old Aug 13, 2007 | 05:06 PM
XtraSlow_XtraCab's Avatar
Did you mess with the tranny at all? Maybe its only a particular gear doing the shuddering? You say between 20mph and 33mph so maybe its 3rd gear being weird?
Old Aug 13, 2007 | 08:18 PM
Kirby's Avatar
It doesn't matter what gear, its seems to do it more if I am turning to the left? I removed the shims from my springs to increase my angle from diff/drive shaft and that seemed to help but didn't cure it. Can the diff angle cause a pretty good vibration? Its bad enough that the change in my ash tray bounces around pretty good.
I pulled the engine/tranny and dropped it straight in to the new frame. It starts at about 20 miles and hour and smooths out the faster I go. I'm just worried its gonna cause me to blow a diff??
Any advice is much appreciated I am suppose to go for a back country trip and don't wanna take the truck if its acting up like this.
I am gonna pull the rear drive shaft and see if it goes away tomorrow. If thats the cause, I'll have at least located the problem.
Kirby
Old Aug 13, 2007 | 08:39 PM
CJM's Avatar
CJM
Rear driveshaft angle is the issue, shimming it like you did is what needs to be played with.
Old Aug 14, 2007 | 07:51 PM
Kirby's Avatar
Ya, I kinda figured(and hoped) that, I put in reverse shims today, gonna try to take it for a test drive on Thursday.
Kirby
duckhead
170
Nov 13, 2017 06:07 AM
jennygirl
Nov 17, 2015 11:24 AM
MadMax48
Jul 3, 2015 08:26 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
