Build up 84 pick up
Old Aug 13, 2007 | 08:28 PM
Kirby's Avatar
Build up 84 pick up
Well I guess its time...
Here is my truck stock, playing around in my friends back yard:
on rip down...
One of 2 breaks in the frame
new frame from an 85 runner
And back together, 4" pro comp, heavy shackes, 4:37 diffs were the major mods on it, but lots of new parts as well.
To follow will be dual transfere cases, Taco lockers(rear to start), wider axle in the rear and spacers in the front, and bigger rubber.
Kirby
Old Aug 14, 2007 | 11:21 AM
navyredneck's Avatar
How did you find a frame in such incredible shape?
Old Aug 14, 2007 | 11:36 AM
85toy's Avatar
I just figured he found a good frame that wasnt rusted out then wire wheeled and painted it.
Old Aug 14, 2007 | 04:01 PM
slacker's Avatar
absolutly .. there are no frames up here that look like that with out work .
good job .. keep the pics commin'
Old Aug 14, 2007 | 04:17 PM
Kaleb's Avatar
How common are 4.37s?
Old Aug 14, 2007 | 07:49 PM
Kirby's Avatar
the frame was off a runner that was parted out in the mid 90's, shifted hands a couple of times before I picked it up. Had it sand blasted then painted it. There was a slight rust patch on the driver side rear right over the tire, I cut it out and welded a 1/8" plate over it.
the 4:37's aren't that common, my friend had them in his 83 but pulled them to drop in 5:29 so I got them super cheap.
Tomorrow I start welding up my rear deck.
Kirby
Old Aug 14, 2007 | 08:18 PM
gotboostedvr6's Avatar
looken good so far keep use updated!!
young buck
18
Aug 27, 2018 02:40 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
defrag4
Jul 31, 2015 10:50 AM
Backcountry411
Jul 24, 2015 08:06 AM
Bflo338
Jul 21, 2015 07:28 AM
