Transmission not engaging gears
Old Jan 8, 2012 | 05:16 PM
Batcavee00's Avatar
I finally got my engine running nice after the rebuild.
i was about to take it for a spin, and put it on drive and nothing happened...
none of the gears worked.. Im not sure what could be wrong, again...
Anyone have a clue? Fluid is good by the way
got an 85 pich up auto tranny 22r
Old Mar 22, 2012 | 06:29 AM
maco35's Avatar
Did you fix your problem? I'm having the same thing with mine, when I shift the selector to D or any other gear nothing happens.
Old Mar 22, 2012 | 06:34 AM
Bassmastry101's Avatar
Probably a dumb question but..Did your transmission shift into drive or just the lever/indicator? Is the shift cable connected?
I ask because you said you just rebuilt the engine...it makes sense to me to check that first
Old Mar 22, 2012 | 06:48 AM
Night-rider123's Avatar
Another dumb question, did you bolt the torque converter back up?
Old Mar 22, 2012 | 07:19 AM
Batcavee00's Avatar
I fixed the issue. My dumbass didnt know that ur suppossed to instal the converter in tranny 1st and then mount the engine, since this was my 1st time messing with an auto tranny I didnt now, so I put converter on engine first and then jamed it on the tranny. Turns out I busted 2 spines that are on the oil pump. So I guess it couldnt generate pressure for gears to engage. I went to my local junk yard and got an used pump for about 20 bucks and bought a new pump seal. Put everything back and boom! I was on the road again......also this truck wont run unless it has enough oil in tranny for people having same isse. I also had my converter rebuild just in case for 40 bucks..
Old Mar 22, 2012 | 07:36 AM
As long as a lesson was learned
Dieselmann
Feb 19, 2019 02:57 AM
mskalmus
May 28, 2017 07:51 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
