Transfer case leak?
Transfer case leak?
My transfer case is slinging oil at the rear drive shaft yoke seal. Can That seal be replaced without droping the transfer?
85 4runner, 22re, W56-a(I think)
Thanks
Thanks
This seal is also on my list of to-do's. If its not an oil pan leak, its a rear output shaft seal leak!! Any pics would help. I have read in other posts you should buy a replacement nut??
God bless guinea pigs with cameras!!
Ha ha... I went to the parts store to get the seal and he didn't know which one it was. I said the rear output shaft seal and he read off like 5 different ones. I wasn't able to get the parts for it yet. I said I'd have to find out more so I can get the right one. So any more help on how to correctly identify the seal would be great. I do not think there is much play or any at all in the drive shaft there. I'd have to check again, but I think I remember checking a little while back.
I'm not sure how else oil would be getting on the drive shaft. It's a ways away from really anything else.
omg!!
Man I feel your pain! They hire some real winners at those parts stores sometimes. Theres now other way to describe it! Its the rear output shaft seal on the transfer case. Maybe go in when someone else is workn
I've found that Napa is the only place for the more specific items we often need. They have been the only place I've gotten things like inner axle seals, and brake line fittings. I try to avoid the generic discount auto parts stores when I can.
