tps adjustment
Old Sep 10, 2008 | 07:56 PM
yodercrawler55's Avatar
Thumbs down tps adjustment
i bought my 4 runner a while ago and the tps seems so be off. What is the ohms supposed to be set at?Any tips? its a 85 22re
Old Sep 13, 2008 | 11:15 PM
pcmentor's Avatar
Try this:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Sep 14, 2008 | 03:52 PM
slacker's Avatar
yes .. leave it alone ...
biggest problem I have run into , is usually by now the throttle shaft bushings are worn .. and adjustment is near impossable .
we need a supply of throttle shaft bushings .. and they are just NOT avaliable .
Old Sep 15, 2008 | 12:33 AM
XtraSlow_XtraCab's Avatar
Pop one off and start comparing. Go to hardware stores, autoparts stores, etc. I replaced shifter bushings in my Datsun 240z with bushings from a Chrysler door hinge repair kit. Brass over rubber... I don't see them breaking and the shift is more firm.
You never know... you're throttle shaft bushings might be sitting on a door linkage setup for some other make and model car.
Old Jul 25, 2009 | 06:06 PM
85TurboRunner's Avatar
I figured I'd just bump this thread instead of making a new one. Anyway Ive been trying to adjust my TPS and I can't get the second setting correct as per 4Crawlers diagram. 1, 3, 4 and 5 come up correct. Does this mean its time for a new TPS? How far out of spec is ok if at all? I get an open infinite reading on the .57mm (actually .58 since I don't have the .57 feeler) setting as well as the .85mm setting. I don't wanna mess with it too much more since it is very close to being correct.
Old Jul 25, 2009 | 08:11 PM
pcmentor's Avatar
What reading do you get for no 2?
Old Jul 26, 2009 | 03:41 AM
Im getting open/infinite where it should be 2.3k.
zytra
Jan 24, 2019 03:16 PM
ZGjethro
Jun 7, 2017 11:04 PM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
dbollier123
Sep 29, 2015 05:23 PM
