Towing a camping trailer
Old Oct 7, 2009 | 10:02 AM
prolite1's Avatar
Anybody out there towing a camping trailer with their 4cyl pickup? I'm looking to get an '85ish truck and wondering what size camping trailer it might tow. Thanks!
Old Oct 7, 2009 | 05:34 PM
aalan's Avatar
If it is a 22r like mine. I would say NONE!
Old Oct 7, 2009 | 06:13 PM
jsn_stockard's Avatar
I tow a 12 ft pop up pretty easily with my 22re, as long as there are not many hills
Old Oct 8, 2009 | 08:13 AM
prolite1's Avatar
That bad! Maybe I should look at something with a little more umph
Old Oct 8, 2009 | 08:19 AM
prolite1's Avatar
Any idea how much your pop up weighs?
Old Oct 8, 2009 | 08:26 AM
MaK92-4RnR's Avatar
they have problems towing their own weight up hill... I wouldn't suggest it.
Old Oct 8, 2009 | 09:05 AM
grant526's Avatar
Partially depends upon how the truck is set up. If it has lower axle gears, you should be able to tow a small pop up. I just installed 5.29s and am running 33s, but have not broken them in enough or had the chance to tow yet. I tow an 18'6" Ski boat (only on relatively flat land so far tho). With stock 4.10s and 31" tires, it was slow, but it got there. With 4.10s and 33's, it was Terrible, but it still got there. I'm interested to see how it does with the 5.29s. I'm WAY under geared with them and the 33s. So towing shouldn't be an issue.
31's with 4.88 axle gears would probably be a good combination. . .
Old Oct 12, 2009 | 11:13 AM
prolite1's Avatar
Thanks for the advice everybody, very helpful!
Old Oct 12, 2009 | 11:33 AM
Trail_Banger's Avatar
My two cents would be that anything 1000 lbs and under, like a popup, you'd be fine. I'll caveat and say that would be fine if you have 31s or smaller under the truck.
Just don't epxect 0-60 in well, 2 or 3 minutes. :-)
Old Oct 13, 2009 | 11:08 AM
grant526's Avatar
Thinking about it, If you look at the Owner's Manual, I believe it says 5,500lbs GVWR (Gross Vehicle Weight Rating) which includes the Truck and the cargo/trailer. My truck weighed in at about 3,500 +/-, the last time I put it on a scale, but I've also added gear, a winch and heavy bumper and sliders since then. So probably 3,700-3,800 easy. Meaning I can only "Safely" within specs tow 1,200 or so.
Old Oct 13, 2009 | 11:44 AM
dropzone's Avatar
Fossilized
not much, as mentioned below 3K, 2K probably better..good brakes on both truck and trailer (whether they are surge-electric brake control would be better) class 3 hitch (2" reciever) forgoet a bumper mounted ball...
I would suggest a bigger truck/suv for a tow rig...
Old Oct 13, 2009 | 12:03 PM
grant526's Avatar
My buddie sent me this link a day or two ago.
http://www.pirate4x4.com/forum/showthread.php?t=826530
It's a pretty cool concept and would be neat to build/have. I don't know what the eventual weight is going to be, but a 4cylinder Yota should be able to pull it.
Old Oct 13, 2009 | 03:34 PM
slacker's Avatar
I'm at ~ 4800 GVW combined .. fully loaded .. stock gears , 31's 22RE .
running up the switch backs on the mountian I had to run in 2nd gear .. but hey , like all other campers , I was in no hurry . on the flats and gravel , not a problem .. I believe the key to success in towing , is excellent brakes and cooling system .. and I always keep both of those in top notch condition .
Old Oct 22, 2009 | 10:40 AM
prolite1's Avatar
That's awesome! I found a little trailer locally that I might buy, it can't weigh more than 900lbs so it should work.
primordialbeast117
Dec 19, 2015 12:23 PM
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
Project90
Sep 24, 2015 11:40 PM
