Timing question...
Old May 21, 2009 | 08:03 AM
chriso's Avatar
Timing question...
So how often should you get youre timing done I can't remember my dad ever doing it its a 85... Around how much does this cost?
Old May 21, 2009 | 08:09 AM
Lumpy's Avatar
Do you mean just set the timing??? I would not think you need to do it at all once it's set. Only if something has changed, cap, rotor, plugs??? Even at that I would not pay to have someone do it. Get a cheap light and have at it.
Old May 21, 2009 | 08:10 AM
4Crawler's Avatar
Which engine?
I usually end up doing my 22RE every 2 years just before taking it in for the smog check, since they check the timing as part of the test. Easy enough to DIY, pick up a timing light and go for it:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old May 21, 2009 | 08:15 AM
chriso's Avatar
its a 85 my dad said it was a 22r is that a re or are they different? I just thought the timing chain "or is it a belt" was something that needed to be done every so many miles...
Old May 21, 2009 | 08:20 AM
4Crawler's Avatar
Setting engine ignition timing is one thing, timing chain is another:
- http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Typically want to do that every 100K miles or so.
22R = carbed engine, 22RE = Electronic fuel injection.
Old May 21, 2009 | 08:26 AM
chriso's Avatar
How bad of problems can come from not doing you're timing chain I don't think my father has ever had it done. Oh yeah its EFI so It's the 22re then.
Old May 21, 2009 | 08:32 AM
4Crawler's Avatar
First symptom is a loose chain, then that wears out/breaks the chain guides that can let the chain chew a hole in the side of the water pump housing and instant milk shake (oil/coolant mix). And if the chain breaks, Mr. Valve says hello to Mr. Piston (i.e. an interference engine).
Old May 21, 2009 | 09:44 AM
Lumpy's Avatar
Something tells me that when Mr. Valve says hello to Mr. Piston that they don't really get along to well.
Old May 21, 2009 | 09:55 AM
WVtoyjon's Avatar
No it is more like Mr. Valve kicking Mr. Piston in the nuts.
Old May 21, 2009 | 10:05 AM
chriso's Avatar
Got it... Any estimates on how much this would cost at a shop?
Old May 21, 2009 | 10:21 AM
toyospearo's Avatar
AHHAHHAHAHHAHAH
Now thats funny right there!!!
Old May 21, 2009 | 10:29 AM
Lumpy's Avatar
I'm sure you can get a timing gun for under $30. It will take you 5 minutes, why pay someone??? Just be sure to jump the diag connections before you time it. http://www.troublecodes.net/Toyota/
But to answer your question about a shop doing it. I have not a clue. Never payed to have it done.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
