Is there a 12VOLT keyed under the hood?
Old Sep 4, 2009 | 05:27 PM
1990arizona4runner's Avatar
Looking for a keyed 12 volt source under the hood to install an electric fan; is there one? And if so where?
1985 4Runner w/ 22re
Old Sep 4, 2009 | 06:47 PM
myyota's Avatar
You should be able to find one in the fuse box by the battery, take a volt meter and start looking.
Old Sep 5, 2009 | 06:20 AM
I already checked those but I guess your right theres gotta be one there somewhere. Ill keep looking.
Old Sep 6, 2009 | 03:38 AM
Wardamneagle's Avatar
I don't know how many amps your electric fan will pull but I suspect you will not find a keyed source under the hood with adequate capacity. You need to use a relay. Pull power from the main fuse block or from the battery directly to a relay of adequate size. Then using a small wire, pull ignition-only power from a source to turn the relay on and off. You can get a small Bosch relay (e.g. 40 Amps) at any auto parts store. I suspect you will have to go to the fuse block behind the driver's side kickboard to get ignition-only power.
This thread might help you a bit:
https://www.yotatech.com/forums/f115...rcuits-146827/
Also you might find this thread helpful.
http://forum.ih8mud.com/79-95-toyota...1-4runner.html
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
Bourbonblues
Dec 15, 2017 05:43 PM
JamesDINAN
Sep 22, 2015 05:37 AM
JHalcyonM
Sep 14, 2015 01:10 AM
