Temp gauge rises then falls
Old May 6, 2012 | 08:27 AM
Joelong258's Avatar
I tried lookin for a similar thread before I posted this but didn't find one. Ok so I got my truck running new rebuilt motor an everything and it wasn't giving me any problems until now. When I start drivig it after its sat an cooled off after a few miles the temp gauge slowly creeps all the way up and almost touches
The red and stays there a few seconds then comes down and goes to normal operating temp. What is causing this thermostat? Water pump?
Old May 6, 2012 | 08:40 AM
rworegon's Avatar
What engine and year? Tough to tell you anything without that information.
Old May 6, 2012 | 08:50 AM
Joelong258's Avatar
Oh I'm sorry. It's a 1986 22re with rebuilt motor bored 20 over new head new cam oil pump etc
Old May 6, 2012 | 08:56 AM
fork's Avatar
i would guess sticking or incorrect thermostat, assuming the gauge is getting a good reading
Old May 6, 2012 | 08:59 AM
rworegon's Avatar
Sounds like the 22RE temp overshoot issue (link in post 5 is full of info):
https://www.yotatech.com/forums/f116...roblem-198444/
https://www.yotatech.com/forums/f116...rshoot-229538/
Old May 6, 2012 | 10:54 AM
Bassmastry101's Avatar
Have you bled all of the air out of the cooling system. If an air bubble gets trapped on the sensor for the gauge it will jump around like that.
Old May 6, 2012 | 11:18 AM
dewiseman's Avatar
temp overshoot
I had this problem in my old truck with 22RE. Only on cold mournings when I hit the freeway before the truck was fully warmed. For me it was a result of using an after market thermostat. Switching to Toyota brand T-stat cured the problem. Since then I've run Toyota t-stats AND Toyota coolant. It does make a difference. If that doesn't take care of it then I would look to a radiator thats not flowing properly. When was the last time you had your radiator professionally cleaned? What Bassmastery said is a good idea also.
Old May 6, 2012 | 11:40 AM
Look into one of these, a two-stage thermostat.
Toyota P/N 90916-03078
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old May 6, 2012 | 11:59 AM
dewiseman's Avatar
temp overshoot
Again what Bassmastery said. Thats what I got from dealership that cured my problem.
Old May 6, 2012 | 12:05 PM
pruney81's Avatar
You need to get a Toyota Dual Stage Thermostat.
Old May 9, 2012 | 12:26 AM
kiwicowboy's Avatar
Easiest was to bleed the cooling system is park your truck on a hill. Start with a cold engine and remove the rad cap and start the engine. When it reaches normal temp and the coolent is circulating, keep topping off the radiator. When it stays at the top, put the cap back on and you're done. Takes about 10 minutes and you can do it by yourself.
TheBFA
Feb 15, 2020 06:55 AM
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
--Oz--
Sep 6, 2015 01:06 AM
