temp gauge help
Old Apr 30, 2011 | 12:23 PM
runs-on-4's Avatar
temp gauge help
my temp gauge doesnt work does anyone know where the sending unit is so i can put in another
Old Apr 30, 2011 | 12:35 PM
BigBluePile's Avatar
....gooogllleee.....knows.......
Old May 15, 2011 | 04:39 PM
alfredo calderon's Avatar
Cool
My gauge doesn't work also. Once was over heating really bad due to a blown hose and the temp gauge staid at the same level as always about 1/4 warm.
Old May 15, 2011 | 04:49 PM
Bassmastry101's Avatar
Check connections on the sensor on the thermostat housing and I think the actual sensor for the gauge is under the intake.
Old May 15, 2011 | 05:58 PM
Jesse, thanks for reply. Will look into it.
Old May 15, 2011 | 06:26 PM
Np
If your overheating and the gauge doesn't read then a theres few things could be wrong. There is not enough water in the system to touch the sensor, so the gauge cannot read the water temp..just kind of feel the heat off of it. The sensor could be bad or going bad..loose connections..or the dash gauge itself needs some attention.
Here's a little info on that gauge..might want to check it out.
https://www.yotatech.com/forums/f116...inally-218848/
ashamsuddin
17
Jul 22, 2024 03:59 AM
Jdgarrison
Oct 1, 2015 05:22 PM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
