TC output shat bearing replacement
I think I have a bad rear output shaft bearing in my TC. The reason I think this, is it just started vibrating when Im driving and gets worse with acceleration. When I get under there and move things around, the only play I see is in the output shaft, so Im thinking I have a bad bearing. It has about a 2" to 3" lift and Ive had the lift on there for along time before this happened, so I dont think its my pinion angle. I have never seperated my driveshaft so I dont think its a phasing issue.
Looking at the back of the TC, it looks like I could just remove the back cover and access the bearing. When looking at the FSM, maybe its not going to be that easy. Your thoughts on these things are appreciated.
Look here Jager http://www.marlincrawler.com/tech/gu...1-gear-install
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
